Lenovo Y700-14ISK Upgrading/Replacing RAM Replacement
  1. Lenovo Y700-14ISK Upgrading/Replacing RAM Replacement, Remove the back Panel: step 1, image 1 of 2 Lenovo Y700-14ISK Upgrading/Replacing RAM Replacement, Remove the back Panel: step 1, image 2 of 2
    • Unscrew and take out 10, 1/5 cm screws.
    • Unscrew and take out 1, 1 inch screw.
    • I use a piece of tape sticky side up to place screws on, also I label it where they go.
  2. Lenovo Y700-14ISK Upgrading/Replacing RAM Replacement, Pry up back panel: step 2, image 1 of 3 Lenovo Y700-14ISK Upgrading/Replacing RAM Replacement, Pry up back panel: step 2, image 2 of 3 Lenovo Y700-14ISK Upgrading/Replacing RAM Replacement, Pry up back panel: step 2, image 3 of 3
    • With the vents facing away from your body I find it easiest to start at the bottom right corner first and gently pry up the corner using a plastic tool.
    • Then slide and pry the plastic tool to the left corner.
    • Then work on the sides.
  3. Lenovo Y700-14ISK Upgrading/Replacing RAM Replacement, Pulling off the back panel: step 3, image 1 of 3 Lenovo Y700-14ISK Upgrading/Replacing RAM Replacement, Pulling off the back panel: step 3, image 2 of 3 Lenovo Y700-14ISK Upgrading/Replacing RAM Replacement, Pulling off the back panel: step 3, image 3 of 3
    • Carefully lift up on the back panel.
    • The back will snap out of place but be careful and don't force it to hard.
  4. Lenovo Y700-14ISK Upgrading/Replacing RAM Replacement, Disconnect the battery: step 4, image 1 of 2 Lenovo Y700-14ISK Upgrading/Replacing RAM Replacement, Disconnect the battery: step 4, image 2 of 2
    • Pull the battery cable out of it's connector. Gripping the wires in the middle gently wiggling the wires back and forth while pulling.
    • With the battery connector out.
  5. Lenovo Y700-14ISK Upgrading/Replacing RAM Replacement, Removing the RAM: step 5, image 1 of 3 Lenovo Y700-14ISK Upgrading/Replacing RAM Replacement, Removing the RAM: step 5, image 2 of 3 Lenovo Y700-14ISK Upgrading/Replacing RAM Replacement, Removing the RAM: step 5, image 3 of 3
    • Note the tabs on each side of the RAM holder,
    • With your fingers or the plastic tool gently move the tabs away from the RAM, the RAM should pop up when both sides or moved.
    • Grip the RAM by the sides and lift out.
5 other people completed this guide.
Corbin Schon
593 Reputation
2 Guides authored
One Comment
Thank you for the guide! It helped me to feel sure about the disassemble.
cacalo219 - Reply
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 29
All Time: 3,803
