Lenovo YOGA 730-15IKB SSD Replacement
  1. Lenovo YOGA 730-15IKB SSD Replacement, Bottom Cover: step 1, image 1 of 2 Lenovo YOGA 730-15IKB SSD Replacement, Bottom Cover: step 1, image 2 of 2
    • Turn off the computer and unplug the charger before going any further.
    • Flip the laptop over so you can see the underside.
    • Remove the ten 7mm T5 Torx screws.
  2. Lenovo YOGA 730-15IKB SSD Replacement: step 2, image 1 of 2 Lenovo YOGA 730-15IKB SSD Replacement: step 2, image 2 of 2
    • Pry up the bottom cover with an opening tool.
    • Start at the front edge of the cover and make your way along the sides.
  3. Lenovo YOGA 730-15IKB SSD Replacement: step 3, image 1 of 1
    • Pull the bottom cover up and away from the back hinges.
  4. Lenovo YOGA 730-15IKB SSD Replacement, SSD: step 4, image 1 of 2 Lenovo YOGA 730-15IKB SSD Replacement, SSD: step 4, image 2 of 2
    • Remove one 2mm Phillips #1 screw.
    • There may be a sticker covering the screw if the laptop is new.
  5. Lenovo YOGA 730-15IKB SSD Replacement: step 5, image 1 of 2 Lenovo YOGA 730-15IKB SSD Replacement: step 5, image 2 of 2
    • Pull the SSD out of the socket at its resting angle.
    • Do not pull straight upward. Pull towards the side of the laptop.
3 other people completed this guide.
Ellis Ruckman
2,647 Reputation
6 Guides authored
Cal Poly, Team S1-G6, White Winter 2020 Member of Cal Poly, Team S1-G6, White Winter 2020
CPSU-WHITE-W20S1G6
3 Members
27 Guides authored
0 Comments
Past 24 Hours: 5
Past 7 Days: 13
Past 30 Days: 71
All Time: 4,804
