Lenovo YOGA 730-15IKB Speaker Replacement
  1. Lenovo YOGA 730-15IKB Speaker Replacement, Bottom Cover: step 1, image 1 of 2 Lenovo YOGA 730-15IKB Speaker Replacement, Bottom Cover: step 1, image 2 of 2
    • Turn off the computer and unplug the charger before going any further.
    • Flip the laptop over so you can see the underside.
    • Remove the ten 7mm T5 Torx screws.
  2. Lenovo YOGA 730-15IKB Speaker Replacement: step 2, image 1 of 2 Lenovo YOGA 730-15IKB Speaker Replacement: step 2, image 2 of 2
    • Pry up the bottom cover with an opening tool.
    • Start at the front edge of the cover and make your way along the sides.
  3. Lenovo YOGA 730-15IKB Speaker Replacement: step 3, image 1 of 1
    • Pull the bottom cover up and away from the back hinges.
  4. Lenovo YOGA 730-15IKB Speaker Replacement, Speaker: step 4, image 1 of 3 Lenovo YOGA 730-15IKB Speaker Replacement, Speaker: step 4, image 2 of 3 Lenovo YOGA 730-15IKB Speaker Replacement, Speaker: step 4, image 3 of 3
    • Disconnect the speaker cable by pulling the wire towards the front of the laptop.
    • You can also use the white tabs on the connector to push the cable free.
  5. Lenovo YOGA 730-15IKB Speaker Replacement: step 5, image 1 of 2 Lenovo YOGA 730-15IKB Speaker Replacement: step 5, image 2 of 2
    • When the laptop is upside down, the left speaker is located on the right side of the computer.
    • Pull up on the left speaker to remove it from the chassis.
    • Do not fully remove the left speaker at this point. Notice that the left and right speakers are still connected by a wire.
  6. Lenovo YOGA 730-15IKB Speaker Replacement: step 6, image 1 of 1
    • Remove the red and black wire near the front of the laptop from underneath the hooks that hold it in place.
  7. Lenovo YOGA 730-15IKB Speaker Replacement: step 7, image 1 of 2 Lenovo YOGA 730-15IKB Speaker Replacement: step 7, image 2 of 2
Ellis Ruckman
2,647 Reputation
6 Guides authored
Cal Poly, Team S1-G6, White Winter 2020 Member of Cal Poly, Team S1-G6, White Winter 2020
CPSU-WHITE-W20S1G6
3 Members
27 Guides authored
One Comment
when the stock can arrive ?
prashantdushara - Reply
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 37
All Time: 1,002
