Lenovo YOGA 730-15IWL Battery Replacement
  1. Lenovo YOGA 730-15IWL Battery Replacement, Remove the base cover screws: step 1, image 1 of 1
    • Remove the screws (M2.0 x 7.0 mm, Torx).
  2. Lenovo YOGA 730-15IWL Battery Replacement, Remove the base cover: step 2, image 1 of 1
    • Remove the base cover. Consider using a spudger.
  3. Lenovo YOGA 730-15IWL Battery Replacement, Remove the battery: step 3, image 1 of 1
    • Unplug the battery connector in the direction shown by arrow
    • Remove the screws (M2.0 x 4.5 mm).
    • Remove the battery pack.
To replace the battery & reassemble your device, follow these instructions in reverse order.
2 other people completed this guide.
Max Kletskov
40,307 Reputation
16 Guides authored
iFixit Member of iFixit
Staff
141 Members
17,895 Guides authored
2 Comments
My issue with my Lenovo Yoga 730-15 laptop was not the battery I just successfully replaced. It still does not turn on. The Power button light up for a short time when pressed to power up the laptop. However, it then goes out and the laptop does not startup. Any Ideas?? Thanks
Al Cross - Reply
Check thermal paste. May be getting hot and shutting back off.
William Mobley - Reply
Past 24 Hours: 1
Past 7 Days: 11
Past 30 Days: 28
All Time: 1,438
