Lenovo Yoga 11e Chromebook Keyboard Replacement
  1. Lenovo Yoga 11e Chromebook Keyboard Replacement, Keyboard: step 1, image 1 of 1
    • There will be 7 Philips head screws on the bottom which will need to be removed to gain access to the battery
    • NOTE: You may void your warranty completing this replacement
  2. Lenovo Yoga 11e Chromebook Keyboard Replacement: step 2, image 1 of 1
    • There are two screws that will need to be removed to access the keyboard.
  3. Lenovo Yoga 11e Chromebook Keyboard Replacement: step 3, image 1 of 2 Lenovo Yoga 11e Chromebook Keyboard Replacement: step 3, image 2 of 2
    • Next, flip the laptop over and open it up. The keyboard can be easily removed by pushing it back from the front. I suggest using a jimmy tool to slip into the tiny gap to push it back.
    • Look closely at the two images you'll notice a slight gap at the bottom if you did this step correctly
  4. Lenovo Yoga 11e Chromebook Keyboard Replacement: step 4, image 1 of 1
    • Pull slightly up from the keyboard but NOT all the way, the ribbon cable is still connected to the motherboard
  5. Lenovo Yoga 11e Chromebook Keyboard Replacement: step 5, image 1 of 3 Lenovo Yoga 11e Chromebook Keyboard Replacement: step 5, image 2 of 3 Lenovo Yoga 11e Chromebook Keyboard Replacement: step 5, image 3 of 3
    • Use a plastic pry tool to lift up the plastic clip holding down the ribbon cable. Be very gentle with it so it doesn't break
Congratulations you’ve successfully removed the keyboard! To reassemble your device, follow these instructions in reverse order.
3 other people completed this guide.
Corey Meyer
2,292 Reputation
2 Guides authored
Kid fixers Member of Kid fixers
Community
169 Members
225 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 32
All Time: 1,916
