Introduction
This guide will show to how to properly remove and replace the touchpad of a Lenovo Yoga 2 11 “ with the serial number 20428.
Flip the computer over so the bottom is facing up.
Remove the ten 6mm screws with a T5 Torx security screwdriver.
Use the Phillips #000 screwdriver to remove the six 3.3 mm screws around the perimeter of the battery.
Use the Phillips #000 screwdriver to remove the single 6.75 mm screw from the center of the battery.
One Comment
Correction to the tools needed. The screws for the bottom panel are T5 Torx, not T4 Torx. T4 will strip the screws.
