Lenovo Yoga 2 11" Battery Replacement
  1. Lenovo Yoga 2 11" Battery Replacement, Back Panel: step 1, image 1 of 1
    • With a T5 Torx screwdriver, remove ten 6.35 mm screws from the back of the laptop.
  2. Lenovo Yoga 2 11" Battery Replacement: step 2, image 1 of 1
    • Carefully separate back panel from laptop.
  3. Lenovo Yoga 2 11" Battery Replacement, Battery: step 3, image 1 of 1
    • Once you have completed the prerequisite guide, locate the battery of the laptop. Remember to disconnect the battery.
  4. Lenovo Yoga 2 11" Battery Replacement: step 4, image 1 of 1
    • Using a #00 Philips Precision Screwdriver, remove the seven 3.175mm screws that hold the battery in place (six on the outside, one in the middle).
  5. Lenovo Yoga 2 11" Battery Replacement: step 5, image 1 of 2 Lenovo Yoga 2 11" Battery Replacement: step 5, image 2 of 2
    Tool used on this step:
    Buy
    • There will be a clip that connects the battery to the rest of the laptop. Unclasp this clip by inserting tweezers into the connection to completely free the battery.
  6. Lenovo Yoga 2 11" Battery Replacement: step 6, image 1 of 1
    • Once all of the wires are detached, carefully remove the battery and replace.
12 other people completed this guide.
Abbey Hickmann
197 Reputation
1 Guide authored
Cal Poly, Team 4-3, Maness Fall 2015 Member of Cal Poly, Team 4-3, Maness Fall 2015
CPSU-MANESS-F15S4G3
4 Members
5 Guides authored
4 Comments
how do I remove unathorized battery error?
Manuel Durugas - Reply
POOR INSTRUCTIONS
You have failed to mention that the battery cable is attached by a clip that requires opening.
Terrible.
You just took pictures of unscrewing. Not Useful.
barguybrady - Reply
Is it possible to use the computer without the battery? I.e. remove the battery and use the laptop with the power cable only.
Lasse E - Reply
The clip?😬how do you remove ?I tried a twizzer,didnt work ,and there a video ?
Estella - Reply
Past 24 Hours: 2
Past 7 Days: 6
Past 30 Days: 40
All Time: 26,930
