Lenovo Yoga 2 13" Battery Replacement
  1. Lenovo Yoga 2 13" Battery Replacement, Back Panel: step 1, image 1 of 1
    • Be sure to power off and unplug your device before you begin your repair.
    • With a T5 Torx screwdriver, remove eleven 6.35 mm screws from the back of the laptop.
  2. Lenovo Yoga 2 13" Battery Replacement: step 2, image 1 of 1
    • Carefully separate back panel from the laptop.
  3. Lenovo Yoga 2 13" Battery Replacement, Battery: step 3, image 1 of 1
    • Locate the battery of the laptop.
  4. Lenovo Yoga 2 13" Battery Replacement: step 4, image 1 of 1
    • To remove the battery, use a Phillips head screwdriver to unscrew three 3.175 mm screws. One will be in the center of the battery (covered by a Lenovo sticker) and the other two are in the corners.
  5. Lenovo Yoga 2 13" Battery Replacement: step 5, image 1 of 1
    • Disconnect the battery from the laptop by pulling the power connector towards the battery.
    • Pull parallel to the battery, not straight up.
  6. Lenovo Yoga 2 13" Battery Replacement: step 6, image 1 of 1
    • Once all wires are unattached to the rest of the computer, remove the battery from the laptop and replace.
12 other people completed this guide.
Nichelle
1,550 Reputation
5 Guides authored
Marist, Team 1-2, Laflen Spring 2015 Member of Marist, Team 1-2, Laflen Spring 2015
MARS-LAFLEN-S15S1G2
3 Members
7 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 8
Past 30 Days: 43
All Time: 31,787
