Lenovo Yoga 2 13" Hinge Bracket Fix
  1. Lenovo Yoga 2 13" Hinge Bracket Fix, Back Panel: step 1, image 1 of 1
    • Be sure to power off and unplug your device before you begin your repair.
    • With a T5 Torx screwdriver, remove eleven 6.35 mm screws from the back of the laptop.
  2. Lenovo Yoga 2 13" Hinge Bracket Fix: step 2, image 1 of 1
    • Carefully separate back panel from the laptop.
  3. Lenovo Yoga 2 13" Hinge Bracket Fix, Loosening the connectors: step 3, image 1 of 3 Lenovo Yoga 2 13" Hinge Bracket Fix, Loosening the connectors: step 3, image 2 of 3 Lenovo Yoga 2 13" Hinge Bracket Fix, Loosening the connectors: step 3, image 3 of 3
    • The video connector can be pulled out with the attached noose. Pull gently possibly supported by lifting the connector with a screwdriver.
    • The other connector can be pushed out on the sides with the help of a screwdriver.
  4. Lenovo Yoga 2 13" Hinge Bracket Fix, Detach hinge.: step 4, image 1 of 2 Lenovo Yoga 2 13" Hinge Bracket Fix, Detach hinge.: step 4, image 2 of 2
    • Unscrew three screws to detach the hinge from the body.
  5. Lenovo Yoga 2 13" Hinge Bracket Fix, Lay open the display.: step 5, image 1 of 3 Lenovo Yoga 2 13" Hinge Bracket Fix, Lay open the display.: step 5, image 2 of 3 Lenovo Yoga 2 13" Hinge Bracket Fix, Lay open the display.: step 5, image 3 of 3
    • Peel out a small plastic cover, pull out center cover and unscrew left and right cover below the display.
  6. Lenovo Yoga 2 13" Hinge Bracket Fix, Removing the display.: step 6, image 1 of 3 Lenovo Yoga 2 13" Hinge Bracket Fix, Removing the display.: step 6, image 2 of 3 Lenovo Yoga 2 13" Hinge Bracket Fix, Removing the display.: step 6, image 3 of 3
    • Once the two screws are loosened, the whole display can be shifted up - don't just pull it away.
    • On reassembly, put the display and cover together slightly shifted, and then gently slide the display back into position.
  7. Lenovo Yoga 2 13" Hinge Bracket Fix, Free the hinge: step 7, image 1 of 3 Lenovo Yoga 2 13" Hinge Bracket Fix, Free the hinge: step 7, image 2 of 3 Lenovo Yoga 2 13" Hinge Bracket Fix, Free the hinge: step 7, image 3 of 3
    • The hinge is attached to the lid with four screws.
    • A cable runs through each hinge, you can just pull out the small rubbery holder.
    • Loosen the screw below it to open the hinge.
  8. Lenovo Yoga 2 13" Hinge Bracket Fix, Adjustening the hinge stiffness.: step 8, image 1 of 1
    • The stiffness of the hinge can be adjusted by loosening the small nuts. One eighth of a turn might be enough - you will have to repeat adjusting them until the hinge has the right stiffness.
9 other people completed this guide.
Sven Meier
291 Reputation
1 Guide authored
16 Comments
Many thanks. Thumbs up!
Simon - Reply
Hi,
Thanks you for your guide. It is amazing but i worry that remove Display guide is not too clear and user may broken the LCD before he stiffness the hinges.
Kim Son
Kim Son Vu - Reply
Can you post the fix for how to tighten hinges for Lenovo IdeaPad Yoga 13 ?
Siva Nasanakota - Reply
what type of nuts are showing in last step? those are hexagonal nuts but with what size?
Wara - Reply
Just followed this howto on my Yoga 2 13: the size of the bolts is 4.5. I know because I only have 4 and 5 sized tools, and they didn't fit. I used pliers too, it works.
Stéphane L -
Past 24 Hours: 2
Past 7 Days: 5
Past 30 Days: 39
All Time: 19,548
