Lenovo Yoga 2 13" Screen Replacement
  1. Lenovo Yoga 2 13" Screen Replacement, Screen: step 1, image 1 of 2 Lenovo Yoga 2 13" Screen Replacement, Screen: step 1, image 2 of 2
    • Using an opening pick, remove one small black rectangle piece on each of the hinge corners to locate screws.
    • Using a Phillips head screwdriver, carefully remove one 4.8 mm screw from each corner.
  2. Lenovo Yoga 2 13" Screen Replacement: step 2, image 1 of 1
    • Using the Jimmy, remove the long centerpiece covering between the hinges.
  3. Lenovo Yoga 2 13" Screen Replacement: step 3, image 1 of 1
    • Detach the screen from the front panel by sliding the screen up about 2mm. Do not pull too far, as there are still connected wires.
  4. Lenovo Yoga 2 13" Screen Replacement: step 4, image 1 of 1
    • Locate the gold wire and follow it to two clips. Remove the clips and the clear tape securing the wire.
    • Gently unsnap the wire from the hooks along the perimeter, and remove any tape along the wire.
  5. Lenovo Yoga 2 13" Screen Replacement: step 5, image 1 of 2 Lenovo Yoga 2 13" Screen Replacement: step 5, image 2 of 2
    • Completely separate the screen from the laptop.
    • During reassembly, remember to set the screen about 2 mm beyond the lid top edge. Then, slide down to engage the hinges.
11 other people completed this guide.
Nichelle
1,550 Reputation
5 Guides authored
Marist, Team 1-2, Laflen Spring 2015 Member of Marist, Team 1-2, Laflen Spring 2015
MARS-LAFLEN-S15S1G2
3 Members
7 Guides authored
3 Comments
Hi Nichelle,
thanks for your guide. Step 1 and 2 - no problem. But how actually did you do step 3? I can't detach the screen, I can just lift it a few millimeters at the corners or at the side, totally hard..
edit: Ok got it: slide the touch-lcd up a bit :)
Simon - Reply
Hey Nichelle, do you have any recommended vendors for both the screen and the digitizer? Thanks!
Emmanuel Duarte - Reply
I used laptopscreen.com.
ken - Reply
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 13
All Time: 16,264
