Lenovo Yoga 3 11 Motherboard Replacement
  1. Lenovo Yoga 3 11 Motherboard Replacement, Lower Case: step 1, image 1 of 1
    • Remove the eleven 6 mm T5 Torx screws securing the lower case.
    • Gently lift the lower case up and away from the device.
  2. Lenovo Yoga 3 11 Motherboard Replacement, Battery: step 2, image 1 of 3 Lenovo Yoga 3 11 Motherboard Replacement, Battery: step 2, image 2 of 3 Lenovo Yoga 3 11 Motherboard Replacement, Battery: step 2, image 3 of 3
    • Remove the two 3 mm Phillips #00 screws securing the battery.
    • There are arrows on the battery indicating the location of the screws.
  3. Lenovo Yoga 3 11 Motherboard Replacement: step 3, image 1 of 1
    Tool used on this step:
    Buy
    • Use a pair of tweezers to gently disconnect the battery connector.
  4. Lenovo Yoga 3 11 Motherboard Replacement: step 4, image 1 of 2 Lenovo Yoga 3 11 Motherboard Replacement: step 4, image 2 of 2
    • Use a pair of tweezers to gently disconnect the speaker cable.
    • Remove the wires from underneath the battery tabs using the tweezers.
  5. Lenovo Yoga 3 11 Motherboard Replacement: step 5, image 1 of 1
    • Carefully remove the battery from the device.
  6. Lenovo Yoga 3 11 Motherboard Replacement, Motherboard: step 6, image 1 of 1
    Buy
    • Use a pair of tweezers to disconnect the motherboard-size of the trackpad ribbon cable. Gently lift up the black tab, and the cable should come free from the ZIF connector.
  7. Lenovo Yoga 3 11 Motherboard Replacement: step 7, image 1 of 1
    • Use a pair of tweezers to disconnect the keyboard ribbon cable from the motherboard ZIF connector. Gently lift up the white tab, and the cable should come free.
  8. Lenovo Yoga 3 11 Motherboard Replacement: step 8, image 1 of 1
    • Use a pair of tweezers to disconnect the motherboard-side of the SD board ribbon cable. Gently lift up the black tab, and then ribbon cable should come free from the ZIF connector.
  9. Lenovo Yoga 3 11 Motherboard Replacement: step 9, image 1 of 1
    • Use the tweezers to unplug the USB port from the motherboard by gently lifting the white connector up from the black motherboard connector.
  10. Lenovo Yoga 3 11 Motherboard Replacement: step 10, image 1 of 1
    • Use a plastic opening tool to gently pry up the screen cable from the motherboard.
  11. Lenovo Yoga 3 11 Motherboard Replacement: step 11, image 1 of 3 Lenovo Yoga 3 11 Motherboard Replacement: step 11, image 2 of 3 Lenovo Yoga 3 11 Motherboard Replacement: step 11, image 3 of 3
    • Use a pair of tweezers to disconnect the "I/O Side" of the ribbon cable connecting the audio jack/USB port assembly to the motherboard. Gently lift up the black tab, and the ribbon cable should come free from the ZIF connector.
    • Use a pair of tweezers to disconnect the "MB Side" of the ribbon cable connecting the audio jack/USB port assembly to the motherboard. Gently lift up the black tab, and the ribbon cable should come free from the ZIF connector.
    • Remove the ribbon cable from the device.
  12. Lenovo Yoga 3 11 Motherboard Replacement: step 12, image 1 of 3 Lenovo Yoga 3 11 Motherboard Replacement: step 12, image 2 of 3 Lenovo Yoga 3 11 Motherboard Replacement: step 12, image 3 of 3
    • Remove the two 2 mm Phillips #00 screws securing the wireless card (top) and the SSD (bottom).
    • Use a pair of tweezers to disconnect the black and white antenna cables that are connected to the wireless card.
    • Gently lift the wireless card and SSD up and out of the device.
  13. Lenovo Yoga 3 11 Motherboard Replacement: step 13, image 1 of 1
    • Remove the three black 2 mm Phillips #00 screws.
    • Remove the single silver 4 mm Phillips #00 screw.
  14. Lenovo Yoga 3 11 Motherboard Replacement: step 14, image 1 of 1
    • Gently lift the motherboard up and out of the device.
3 other people completed this guide.
Chandler Morris
172 Reputation
1 Guide authored
USF Tampa, Team 2-3, Blackwell Fall 2015 Member of USF Tampa, Team 2-3, Blackwell Fall 2015
USFT-BLACKWELL-F15S2G3
4 Members
11 Guides authored
One Comment
Not as difficult as I thought. I was surprised that there were no empty RAM locations. Usually on a Notebookk lliek this, there is one RAM location soldered to MB, and one empty slot for upgrade. I worked on an identical Yoga 3 pro that ran 16GB. But aht meant it was soldered at factory to one 16GB RAM setup.
Mick Thielen - Reply
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 10
All Time: 7,462
