Lenovo Yoga 3 11 SSD Replacement
  1. Lenovo Yoga 3 11 SSD Replacement, Lower Case: step 1, image 1 of 1
    • Remove the eleven 6 mm T5 Torx screws securing the lower case.
    • Gently lift the lower case up and away from the device.
  2. Lenovo Yoga 3 11 SSD Replacement, Battery: step 2, image 1 of 3 Lenovo Yoga 3 11 SSD Replacement, Battery: step 2, image 2 of 3 Lenovo Yoga 3 11 SSD Replacement, Battery: step 2, image 3 of 3
    • Remove the two 3 mm Phillips #00 screws securing the battery.
    • There are arrows on the battery indicating the location of the screws.
  3. Lenovo Yoga 3 11 SSD Replacement: step 3, image 1 of 1
    Tool used on this step:
    Buy
    • Use a pair of tweezers to gently disconnect the battery connector.
  4. Lenovo Yoga 3 11 SSD Replacement: step 4, image 1 of 2 Lenovo Yoga 3 11 SSD Replacement: step 4, image 2 of 2
    • Use a pair of tweezers to gently disconnect the speaker cable.
    • Remove the wires from underneath the battery tabs using the tweezers.
  5. Lenovo Yoga 3 11 SSD Replacement: step 5, image 1 of 1
    • Carefully remove the battery from the device.
  6. Lenovo Yoga 3 11 SSD Replacement, SSD: step 6, image 1 of 1
    Buy
    • Use a pair of tweezers to disconnect the motherboard-size of the trackpad ribbon cable. Gently lift up the black tab, and the cable should come free from the ZIF connector.
  7. Lenovo Yoga 3 11 SSD Replacement: step 7, image 1 of 1
    • Use a pair of tweezers to disconnect the keyboard ribbon cable from the motherboard ZIF connector. Gently lift up the white tab, and the cable should come free.
  8. Lenovo Yoga 3 11 SSD Replacement: step 8, image 1 of 1
    • Use a pair of tweezers to disconnect the motherboard-side of the SD board ribbon cable. Gently lift up the black tab, and then ribbon cable should come free from the ZIF connector.
  9. Lenovo Yoga 3 11 SSD Replacement: step 9, image 1 of 1
    • Use the tweezers to unplug the USB port from the motherboard by gently lifting the white connector up from the black motherboard connector.
  10. Lenovo Yoga 3 11 SSD Replacement: step 10, image 1 of 1
    • Use a plastic opening tool to gently pry up the screen cable from the motherboard.
  11. Lenovo Yoga 3 11 SSD Replacement: step 11, image 1 of 2 Lenovo Yoga 3 11 SSD Replacement: step 11, image 2 of 2
    • Remove the single 2 mm Phillips #00 screw securing the SSD.
    • Gently lift the SSD up and out of the device.
Geoff Wacker
91,064 Reputation
89 Guides authored
4 Comments
Perché non posso passare direttamente dallo step 2 allo step 11 ?
Keyman - Reply
Same(ish) question as Keyman: why not steps 1, possibly 3, then 11? Why disconnect everything if the SSD is fully exposed when the bottom comes off?
ifaxit - Reply
Basta infatti scollegare la batteria per evitare eventuali ritorni di massa prima di sostituire l'ssd
IRREAL - Reply
he thought that was ram and drilled further to find the ssd perhaps.
furterers - Reply
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 25
All Time: 10,079
