Lenovo Yoga 3 11 Speaker Replacement
  1. Lenovo Yoga 3 11 Speaker Replacement, Lower Case: step 1, image 1 of 1
    • Remove the eleven 6 mm T5 Torx screws securing the lower case.
    • Gently lift the lower case up and away from the device.
  2. Lenovo Yoga 3 11 Speaker Replacement, Battery: step 2, image 1 of 3 Lenovo Yoga 3 11 Speaker Replacement, Battery: step 2, image 2 of 3 Lenovo Yoga 3 11 Speaker Replacement, Battery: step 2, image 3 of 3
    • Remove the two 3 mm Phillips #00 screws securing the battery.
    • There are arrows on the battery indicating the location of the screws.
  3. Lenovo Yoga 3 11 Speaker Replacement: step 3, image 1 of 1
    Tool used on this step:
    Buy
    • Use a pair of tweezers to gently disconnect the battery connector.
  4. Lenovo Yoga 3 11 Speaker Replacement: step 4, image 1 of 2 Lenovo Yoga 3 11 Speaker Replacement: step 4, image 2 of 2
    • Use a pair of tweezers to gently disconnect the speaker cable.
    • Remove the wires from underneath the battery tabs using the tweezers.
  5. Lenovo Yoga 3 11 Speaker Replacement: step 5, image 1 of 1
    • Carefully remove the battery from the device.
  6. Lenovo Yoga 3 11 Speaker Replacement, Speaker: step 6, image 1 of 2 Lenovo Yoga 3 11 Speaker Replacement, Speaker: step 6, image 2 of 2
    Buy
    • Use a pair of tweezers to peel up one side of each of the 3 pieces of tape that cover the speaker wires.
  7. Lenovo Yoga 3 11 Speaker Replacement: step 7, image 1 of 2 Lenovo Yoga 3 11 Speaker Replacement: step 7, image 2 of 2
    • Use a pair of tweezers to disconnect the ZIF connector securing the trackpad ribbon cable. Gently lift the black tab up, and the cable should come free.
  8. Lenovo Yoga 3 11 Speaker Replacement: step 8, image 1 of 3 Lenovo Yoga 3 11 Speaker Replacement: step 8, image 2 of 3 Lenovo Yoga 3 11 Speaker Replacement: step 8, image 3 of 3
    • Remove the two 2 mm Phillips #0 screws securing the left speaker.
    • Remove the two 2 mm Phillips #0 screws securing the right speaker.
  9. Lenovo Yoga 3 11 Speaker Replacement: step 9, image 1 of 2 Lenovo Yoga 3 11 Speaker Replacement: step 9, image 2 of 2
    • Use a pair of tweezers to disconnect the speaker connector.
    • Gently lift the speakers free of the device.
Slade Fernandes
532 Reputation
3 Guides authored
USF Tampa, Team 2-3, Blackwell Fall 2015 Member of USF Tampa, Team 2-3, Blackwell Fall 2015
USFT-BLACKWELL-F15S2G3
4 Members
11 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 2
All Time: 1,256
