Lenovo Yoga 3 11 Trackpad Replacement
  1. Lenovo Yoga 3 11 Trackpad Replacement, Lower Case: step 1, image 1 of 1
    • Remove the eleven 6 mm T5 Torx screws securing the lower case.
    • Gently lift the lower case up and away from the device.
  2. Lenovo Yoga 3 11 Trackpad Replacement, Battery: step 2, image 1 of 3 Lenovo Yoga 3 11 Trackpad Replacement, Battery: step 2, image 2 of 3 Lenovo Yoga 3 11 Trackpad Replacement, Battery: step 2, image 3 of 3
    • Remove the two 3 mm Phillips #00 screws securing the battery.
    • There are arrows on the battery indicating the location of the screws.
  3. Lenovo Yoga 3 11 Trackpad Replacement: step 3, image 1 of 1
    Tool used on this step:
    Buy
    • Use a pair of tweezers to gently disconnect the battery connector.
  4. Lenovo Yoga 3 11 Trackpad Replacement: step 4, image 1 of 2 Lenovo Yoga 3 11 Trackpad Replacement: step 4, image 2 of 2
    • Use a pair of tweezers to gently disconnect the speaker cable.
    • Remove the wires from underneath the battery tabs using the tweezers.
  5. Lenovo Yoga 3 11 Trackpad Replacement: step 5, image 1 of 1
    • Carefully remove the battery from the device.
  6. Lenovo Yoga 3 11 Trackpad Replacement, Trackpad: step 6, image 1 of 1
    • Remove the four 2 mm Phillips #0 securing the trackpad.
  7. Lenovo Yoga 3 11 Trackpad Replacement: step 7, image 1 of 1
    Buy
    • Use the tweezers to partially remove the tape.
  8. Lenovo Yoga 3 11 Trackpad Replacement: step 8, image 1 of 2 Lenovo Yoga 3 11 Trackpad Replacement: step 8, image 2 of 2
    • Use a pair of tweezers to disconnect the ZIF connector securing the trackpad ribbon cable. Gently lift up the black tab and the ribbon cable should come free.
  9. Lenovo Yoga 3 11 Trackpad Replacement: step 9, image 1 of 2 Lenovo Yoga 3 11 Trackpad Replacement: step 9, image 2 of 2
    • Slightly push down with your thumb to pop out the trackpad.
    • The laptop must be slightly open in order for the trackpad to pop out.
Slade Fernandes
532 Reputation
3 Guides authored
USF Tampa, Team 2-3, Blackwell Fall 2015 Member of USF Tampa, Team 2-3, Blackwell Fall 2015
USFT-BLACKWELL-F15S2G3
4 Members
11 Guides authored
One Comment
Very brief, great illustrations. Now, I need to try it.
M T Martinez - Reply
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 5
All Time: 2,913
