Lenovo Yoga 3 14 Cooling Fan Replacement
  1. Lenovo Yoga 3 14 Cooling Fan Replacement, Back Case: step 1, image 1 of 1
    • Remove the eleven 6mm T5 Torx screws from the back case.
  2. Lenovo Yoga 3 14 Cooling Fan Replacement: step 2, image 1 of 3 Lenovo Yoga 3 14 Cooling Fan Replacement: step 2, image 2 of 3 Lenovo Yoga 3 14 Cooling Fan Replacement: step 2, image 3 of 3
    • Insert the plastic opening tool into the long side of the case backing and slide it the entire length of the laptop.
    • Gently lift the backing off the laptop.
  3. Lenovo Yoga 3 14 Cooling Fan Replacement, Cooling Fan: step 3, image 1 of 2 Lenovo Yoga 3 14 Cooling Fan Replacement, Cooling Fan: step 3, image 2 of 2
    • Remove the two 3mm screws using the PH#0 screwdriver head.
    • Unscrew the three 4mm screws using PH#1 (the larger screws do not come off the are attached to the housing unit of the cooling fan).
  4. Lenovo Yoga 3 14 Cooling Fan Replacement: step 4, image 1 of 3 Lenovo Yoga 3 14 Cooling Fan Replacement: step 4, image 2 of 3 Lenovo Yoga 3 14 Cooling Fan Replacement: step 4, image 3 of 3
    Tool used on this step:
    Buy
    • Use tweezers to disconnect the fan.
    • Unwrap the white and black wires from around the fan case.
  5. Lenovo Yoga 3 14 Cooling Fan Replacement: step 5, image 1 of 1
    • Gently lift the fan out of the laptop.
Matthew Victores
602 Reputation
5 Guides authored
USF Tampa, Team 3-2, Passmore Fall 2016 Member of USF Tampa, Team 3-2, Passmore Fall 2016
USFT-PASSMORE-F16S3G2
4 Members
7 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 6
All Time: 3,183
