Lenovo Yoga 3 14 Ram Replacement
  1. Lenovo Yoga 3 14 Ram Replacement, Back Case: step 1, image 1 of 1
    • Remove the eleven 6mm T5 Torx screws from the back case.
  2. Lenovo Yoga 3 14 Ram Replacement: step 2, image 1 of 3 Lenovo Yoga 3 14 Ram Replacement: step 2, image 2 of 3 Lenovo Yoga 3 14 Ram Replacement: step 2, image 3 of 3
    • Insert the plastic opening tool into the long side of the case backing and slide it the entire length of the laptop.
    • Gently lift the backing off the laptop.
  3. Lenovo Yoga 3 14 Ram Replacement, Ram: step 3, image 1 of 2 Lenovo Yoga 3 14 Ram Replacement, Ram: step 3, image 2 of 2
    • Using your thumbs, gently push the two clips away from the RAM.
  4. Lenovo Yoga 3 14 Ram Replacement: step 4, image 1 of 2 Lenovo Yoga 3 14 Ram Replacement: step 4, image 2 of 2
    • After the clips are moved, the RAM will simply pop up.
    • Gently remove the ram.
Matthew Victores
602 Reputation
5 Guides authored
USF Tampa, Team 3-2, Passmore Fall 2016 Member of USF Tampa, Team 3-2, Passmore Fall 2016
USFT-PASSMORE-F16S3G2
4 Members
7 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 8
All Time: 2,628
