Lenovo Yoga 3 14 USB Port Replacement
  1. Lenovo Yoga 3 14 USB Port Replacement, Back Case: step 1, image 1 of 1
    • Remove the eleven 6mm T5 Torx screws from the back case.
  2. Lenovo Yoga 3 14 USB Port Replacement: step 2, image 1 of 3 Lenovo Yoga 3 14 USB Port Replacement: step 2, image 2 of 3 Lenovo Yoga 3 14 USB Port Replacement: step 2, image 3 of 3
    • Insert the plastic opening tool into the long side of the case backing and slide it the entire length of the laptop.
    • Gently lift the backing off the laptop.
  3. Lenovo Yoga 3 14 USB Port Replacement, Battery: step 3, image 1 of 1
    • Remove the four 3mm PH#0 screws surrounding the battery.
  4. Lenovo Yoga 3 14 USB Port Replacement: step 4, image 1 of 3 Lenovo Yoga 3 14 USB Port Replacement: step 4, image 2 of 3 Lenovo Yoga 3 14 USB Port Replacement: step 4, image 3 of 3
    • Gently lift the battery and use the plastic opening tool to remove the battery's connection to the laptop.
  5. Lenovo Yoga 3 14 USB Port Replacement, USB Port: step 5, image 1 of 2 Lenovo Yoga 3 14 USB Port Replacement, USB Port: step 5, image 2 of 2
    • Take out the 3, 3mm screws from the left hinge using the PH0 head.
    • Remove the 1, 4mm screw that connects the hinge to the USB port.
    • Carefully lift the hinge enough to separate it from the USB port.
  6. Lenovo Yoga 3 14 USB Port Replacement: step 6, image 1 of 2 Lenovo Yoga 3 14 USB Port Replacement: step 6, image 2 of 2
    Tool used on this step:
    Buy
    • Using the tweezers, carefully lift the black clip and remove the electrical ribbon.
  7. Lenovo Yoga 3 14 USB Port Replacement: step 7, image 1 of 1
    • The USB port is held in place by plastic pegs. Gently lift up to remove the USB port from the laptop.
2 other people completed this guide.
Matthew Victores
602 Reputation
5 Guides authored
USF Tampa, Team 3-2, Passmore Fall 2016 Member of USF Tampa, Team 3-2, Passmore Fall 2016
USFT-PASSMORE-F16S3G2
4 Members
7 Guides authored
2 Comments
Anyone know where I can buy this part? Cannot find it anywhere…
Nicolas Petersen - Reply
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 18
All Time: 2,193
