Lenovo Yoga 3 Pro Motherboard Replacement
Archived Guide
This guide is retained solely for historical purposes. Use the updated version of the guide to perform your repair.
  1. Lenovo Yoga 3 Pro Motherboard Replacement, Back Panel: step 1, image 1 of 2 Lenovo Yoga 3 Pro Motherboard Replacement, Back Panel: step 1, image 2 of 2
    • Flip the laptop so that the back panel is facing up.
    • Remove the ten 4.0mm T6 Torx screws from the back of the laptop.
  2. Lenovo Yoga 3 Pro Motherboard Replacement: step 2, image 1 of 1
    • Gently lift the back cover off of the laptop.
  3. Lenovo Yoga 3 Pro Motherboard Replacement, Battery: step 3, image 1 of 2 Lenovo Yoga 3 Pro Motherboard Replacement, Battery: step 3, image 2 of 2
    • Push the black battery cable towards the battery to disconnect it.
  4. Lenovo Yoga 3 Pro Motherboard Replacement: step 4, image 1 of 2 Lenovo Yoga 3 Pro Motherboard Replacement: step 4, image 2 of 2
    • Remove the six #0 3.8mm Phillips screws from the battery.
  5. Lenovo Yoga 3 Pro Motherboard Replacement: step 5, image 1 of 1
    • Gently lift the battery out of the laptop chassis.
  6. Lenovo Yoga 3 Pro Motherboard Replacement, Wireless Card: step 6, image 1 of 2 Lenovo Yoga 3 Pro Motherboard Replacement, Wireless Card: step 6, image 2 of 2
    • Using the plastic opening tool, gently pry the grey wire off the wifi card.
    • Pry the black wire off the wifi card.
  7. Lenovo Yoga 3 Pro Motherboard Replacement: step 7, image 1 of 1
    • Remove the one #0 2.9mm Phillips screw from the base of the wifi card.
  8. Lenovo Yoga 3 Pro Motherboard Replacement: step 8, image 1 of 2 Lenovo Yoga 3 Pro Motherboard Replacement: step 8, image 2 of 2
    • Gently lift and pull the wifi card out.
  9. Lenovo Yoga 3 Pro Motherboard Replacement, SSD: step 9, image 1 of 2 Lenovo Yoga 3 Pro Motherboard Replacement, SSD: step 9, image 2 of 2
    • Remove the one #0 2.9mm Phillips screw from the SSD.
  10. Lenovo Yoga 3 Pro Motherboard Replacement: step 10, image 1 of 1
    • Gently lift and wiggle the SSD side to side to remove it from the laptop chassis.
  11. Lenovo Yoga 3 Pro Motherboard Replacement, Motherboard: step 11, image 1 of 3 Lenovo Yoga 3 Pro Motherboard Replacement, Motherboard: step 11, image 2 of 3 Lenovo Yoga 3 Pro Motherboard Replacement, Motherboard: step 11, image 3 of 3
    • Push the cable away from the motherboard.
  12. Lenovo Yoga 3 Pro Motherboard Replacement: step 12, image 1 of 3 Lenovo Yoga 3 Pro Motherboard Replacement: step 12, image 2 of 3 Lenovo Yoga 3 Pro Motherboard Replacement: step 12, image 3 of 3
    • Remove the two #0 2.9mm Phillips screws from the daughter board.
  13. Lenovo Yoga 3 Pro Motherboard Replacement: step 13, image 1 of 1
    • Lift the daughter board with the plastic opening tool.
    • You will hear two clicks when lifting the daughter board.
  14. Lenovo Yoga 3 Pro Motherboard Replacement: step 14, image 1 of 3 Lenovo Yoga 3 Pro Motherboard Replacement: step 14, image 2 of 3 Lenovo Yoga 3 Pro Motherboard Replacement: step 14, image 3 of 3
    • Lift the daughter board, unrouting the wireless cables from their plastic holders, and place it to the side.
  15. Lenovo Yoga 3 Pro Motherboard Replacement: step 15, image 1 of 3 Lenovo Yoga 3 Pro Motherboard Replacement: step 15, image 2 of 3 Lenovo Yoga 3 Pro Motherboard Replacement: step 15, image 3 of 3
    • Gently lift the metal tabs on the daughter board to free the wires.
  16. Lenovo Yoga 3 Pro Motherboard Replacement: step 16, image 1 of 3 Lenovo Yoga 3 Pro Motherboard Replacement: step 16, image 2 of 3 Lenovo Yoga 3 Pro Motherboard Replacement: step 16, image 3 of 3
    • Detach the five flat flex cables attached to the motherboard as follows:
    • 1. Flip the cable holder up with a finger nail
    • 2. Pull on the tab to remove the cable.
    • The large black flat flex labeled 'MB' does not have a tab so gently tug the cable free from the end after flipping the cable holder.
  17. Lenovo Yoga 3 Pro Motherboard Replacement: step 17, image 1 of 3 Lenovo Yoga 3 Pro Motherboard Replacement: step 17, image 2 of 3 Lenovo Yoga 3 Pro Motherboard Replacement: step 17, image 3 of 3
    • Remove the four #0 2.3mm Phillips screws holding down the motherboard.
    • Remove the two #0 2.9mm Phillips screws holding down the fan.
  18. Lenovo Yoga 3 Pro Motherboard Replacement: step 18, image 1 of 3 Lenovo Yoga 3 Pro Motherboard Replacement: step 18, image 2 of 3 Lenovo Yoga 3 Pro Motherboard Replacement: step 18, image 3 of 3
    • Make sure the motherboard and fan are not caught on anything when flipping it over.
    • Gently lift and flip the motherboard over.
  19. Lenovo Yoga 3 Pro Motherboard Replacement: step 19, image 1 of 3 Lenovo Yoga 3 Pro Motherboard Replacement: step 19, image 2 of 3 Lenovo Yoga 3 Pro Motherboard Replacement: step 19, image 3 of 3
    • Flip the cable lock holding down the monitor connector.
    • Remove the monitor connector by tugging on the tab.
5 other people completed this guide.
Nathan Lui
839 Reputation
5 Guides authored
Cal Poly, Team S13-G6, Forte Spring 2017 Member of Cal Poly, Team S13-G6, Forte Spring 2017
CPSU-FORTE-S17S13G6
4 Members
12 Guides authored
2 Comments
There is a tremendous difference between this model and the lenovo yoga 4 900-13ISK.
These instructions do not apply, but some steps are similar
corey - Reply
Hi. Do you have any idea where I could by a replacement motherboard and how much that would cost? Please answer to martin.loffler@gmail.com. Thank you so much. Best, Martin
Martin Loffler - Reply
Past 24 Hours: 6
Past 7 Days: 11
Past 30 Days: 44
All Time: 7,692
