Lenovo Yoga 3 Pro Speakers Replacement
  1. Lenovo Yoga 3 Pro Speakers Replacement, Battery: step 1, image 1 of 1
    • Before opening your laptop, make sure it is powered off.
    • Remove the ten 3.3 mm screws from the base cover using a T5 Torx screwdriver.
  2. Lenovo Yoga 3 Pro Speakers Replacement: step 2, image 1 of 1
    • Slide the plastic opening tool between the base cover and the frame to pry open the computer.
    • Slowly go around the entire perimeter of the computer until all edges are loose.
    • Make sure the plastic opening tool doesn't go too far into the device.
  3. Lenovo Yoga 3 Pro Speakers Replacement: step 3, image 1 of 1
    • Remove the panel and place it in a safe location.
  4. Lenovo Yoga 3 Pro Speakers Replacement: step 4, image 1 of 1
    • Remove the six 3.5 mm screws surrounding the battery using a Phillips 00 screwdriver.
  5. Lenovo Yoga 3 Pro Speakers Replacement: step 5, image 1 of 1
    Tool used on this step:
    Buy
    • Using either tweezers or your fingers, disconnect the black battery cable by pinching either side of the connector and pulling towards the battery.
  6. Lenovo Yoga 3 Pro Speakers Replacement: step 6, image 1 of 1
    • Carefully lift and remove the battery.
  7. Lenovo Yoga 3 Pro Speakers Replacement, Speakers: step 7, image 1 of 1
    • Remove the four 4 mm screws using the Phillips 00 screwdriver.
  8. Lenovo Yoga 3 Pro Speakers Replacement: step 8, image 1 of 2 Lenovo Yoga 3 Pro Speakers Replacement: step 8, image 2 of 2
    • Using the plastic opening tool, flip open tab as shown.
  9. Lenovo Yoga 3 Pro Speakers Replacement: step 9, image 1 of 3 Lenovo Yoga 3 Pro Speakers Replacement: step 9, image 2 of 3 Lenovo Yoga 3 Pro Speakers Replacement: step 9, image 3 of 3
    • Remove the adhesive tape.
    • Flip open the ribbon connecting tab.
    • Carefully lift the ribbon connector from its adhesive.
  10. Lenovo Yoga 3 Pro Speakers Replacement: step 10, image 1 of 2 Lenovo Yoga 3 Pro Speakers Replacement: step 10, image 2 of 2
    • Remove the speaker and set it on the side.
    • Use the plastic opening tool to remove the cables.
    • Be careful of other cables.
  11. Lenovo Yoga 3 Pro Speakers Replacement: step 11, image 1 of 2 Lenovo Yoga 3 Pro Speakers Replacement: step 11, image 2 of 2
    • Removing the other speaker by unwinding cables.
    • Lift both speakers carefully.
2 other people completed this guide.
Caroline Seifert
541 Reputation
2 Guides authored
Cal Poly, Team 12-17, Maness Fall 2015 Member of Cal Poly, Team 12-17, Maness Fall 2015
CPSU-MANESS-F15S12G17
4 Members
15 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 2,797
