Lenovo Yoga 3 Pro Wireless Card Replacement
Archived Guide
This guide is retained solely for historical purposes. Use the updated version of the guide to perform your repair.
  1. Lenovo Yoga 3 Pro Wireless Card Replacement, Back Panel: step 1, image 1 of 2 Lenovo Yoga 3 Pro Wireless Card Replacement, Back Panel: step 1, image 2 of 2
    • Flip the laptop so that the back panel is facing up.
    • Remove the ten 4.0mm T6 Torx screws from the back of the laptop.
  2. Lenovo Yoga 3 Pro Wireless Card Replacement: step 2, image 1 of 1
    • Gently lift the back cover off of the laptop.
  3. Lenovo Yoga 3 Pro Wireless Card Replacement, Battery: step 3, image 1 of 2 Lenovo Yoga 3 Pro Wireless Card Replacement, Battery: step 3, image 2 of 2
    • Push the black battery cable towards the battery to disconnect it.
  4. Lenovo Yoga 3 Pro Wireless Card Replacement: step 4, image 1 of 2 Lenovo Yoga 3 Pro Wireless Card Replacement: step 4, image 2 of 2
    • Remove the six #0 3.8mm Phillips screws from the battery.
  5. Lenovo Yoga 3 Pro Wireless Card Replacement: step 5, image 1 of 1
    • Gently lift the battery out of the laptop chassis.
  6. Lenovo Yoga 3 Pro Wireless Card Replacement, Wireless Card: step 6, image 1 of 2 Lenovo Yoga 3 Pro Wireless Card Replacement, Wireless Card: step 6, image 2 of 2
    • Using the plastic opening tool, gently pry the grey wire off the wifi card.
    • Pry the black wire off the wifi card.
  7. Lenovo Yoga 3 Pro Wireless Card Replacement: step 7, image 1 of 1
    • Remove the one #0 2.9mm Phillips screw from the base of the wifi card.
  8. Lenovo Yoga 3 Pro Wireless Card Replacement: step 8, image 1 of 2 Lenovo Yoga 3 Pro Wireless Card Replacement: step 8, image 2 of 2
    • Gently lift and pull the wifi card out.
2 other people completed this guide.
Aaron Rice
373 Reputation
1 Guide authored
Cal Poly, Team S13-G6, Forte Spring 2017 Member of Cal Poly, Team S13-G6, Forte Spring 2017
CPSU-FORTE-S17S13G6
4 Members
12 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 18
All Time: 2,645
