Lenovo Yoga 700-11ISK Solid State Drive Replacement
  1. Lenovo Yoga 700-11ISK Solid State Drive Replacement, Back Panel: step 1, image 1 of 2 Lenovo Yoga 700-11ISK Solid State Drive Replacement, Back Panel: step 1, image 2 of 2
    • Flip your device so that the bottom panel is facing up.
    • Remove the eleven 5mm Torx T5 screws from the back panel.
  2. Lenovo Yoga 700-11ISK Solid State Drive Replacement: step 2, image 1 of 1
    • Use a spudger to unclip clips on the front and near the USB ports on each side
    • Lift the back panel off
  3. Lenovo Yoga 700-11ISK Solid State Drive Replacement, Battery: step 3, image 1 of 1
    • Remove the two 3mm Phillips #1 screws holding the battery to the laptop chassis.
    • Disconnect the battery from the IO board by holding the connector by the sides and gently pulling the connector out.
  4. Lenovo Yoga 700-11ISK Solid State Drive Replacement: step 4, image 1 of 1
    • Carefully remove the battery from the laptop.
    • Make sure that all wires still connected to the laptop are out of the way and not pulled out with the battery.
  5. Lenovo Yoga 700-11ISK Solid State Drive Replacement, Solid State Drive: step 5, image 1 of 1
    • Remove the one 2mm Phillips #1 screw holding the hard drive to the laptop.
  6. Lenovo Yoga 700-11ISK Solid State Drive Replacement: step 6, image 1 of 1
    • Pull the solid state disk out of the connector and lift it out of the laptop.
    • Make sure the hard drive is oriented correctly with the label facing up before re-inserting.
8 other people completed this guide.
Emma Morley
378 Reputation
2 Guides authored
Cal Poly, Team 15-6, Livingston Fall 2016 Member of Cal Poly, Team 15-6, Livingston Fall 2016
CPSU-LIVINGSTON-F16S15G6
4 Members
7 Guides authored
3 Comments
How to transfer the windows os to the newly install Crucial ssd?
Bernardino Santiago - Reply
how to transfer the windows OS to the newly install ssd?
Specification for the M.2 SSD: Make sure it’s a Type 2280 (22mm x 80mm) SATA M.2 with B and M key edge connector, not the B key used on NvMe M.2 for PCIe. It’s easy to confuse the two when ordering online.
Joe Rhio - Reply
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 28
All Time: 5,248
