Lenovo Yoga 710-11ISK Motherboard Replacement
  1. Lenovo Yoga 710-11ISK Motherboard Replacement, Motherboard: step 1, image 1 of 1
    • Remove the eleven screws that attach the back panel using a T5 Torx screwdriver.
  2. Lenovo Yoga 710-11ISK Motherboard Replacement: step 2, image 1 of 1
    • Insert an opening tool between the bottom panel and chassis, then pry around the entire perimeter until the five clips detach, releasing the bottom panel.
  3. Lenovo Yoga 710-11ISK Motherboard Replacement: step 3, image 1 of 2 Lenovo Yoga 710-11ISK Motherboard Replacement: step 3, image 2 of 2
    • Use a Phillips #000 screwdriver to remove the four screws securing the battery.
    • Hold the cable connector on both sides and gently pull it directly out of its port.
    • Lift the battery up and out.
  4. Lenovo Yoga 710-11ISK Motherboard Replacement: step 4, image 1 of 2 Lenovo Yoga 710-11ISK Motherboard Replacement: step 4, image 2 of 2
    • Use a Phillips #000 screwdriver to remove the eight screws securing the motherboard, Wi-Fi card, and SSD card.
    • Unplug the Wi-Fi and SSD cards from the motherboard along with the attached wire harnesses.
  5. Lenovo Yoga 710-11ISK Motherboard Replacement: step 5, image 1 of 2 Lenovo Yoga 710-11ISK Motherboard Replacement: step 5, image 2 of 2
    • Lift the motherboard up and out.
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 8
All Time: 187
