Lenovo Yoga 710-11ISK SSD Replacement
  1. Lenovo Yoga 710-11ISK SSD Replacement, Back Panel: step 1, image 1 of 2 Lenovo Yoga 710-11ISK SSD Replacement, Back Panel: step 1, image 2 of 2
    • Make sure back panel is facing up.
    • Remove eleven 5mm screws with the T5 Torx Screwdriver.
  2. Lenovo Yoga 710-11ISK SSD Replacement: step 2, image 1 of 1
    • Lift back panel carefully.
    • You can now replace back cover, making sure to match screw holes and placement of the original.
  3. Lenovo Yoga 710-11ISK SSD Replacement, SSD: step 3, image 1 of 2 Lenovo Yoga 710-11ISK SSD Replacement, SSD: step 3, image 2 of 2
    • Use a Phillips #00 screwdriver to remove the single 3 mm screw on the right of the SSD.
  4. Lenovo Yoga 710-11ISK SSD Replacement: step 4, image 1 of 1
    • Disconnect and pull the SSD out of the motherboard.
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 7
All Time: 309
