Lenovo Yoga 710-11ISK Speaker Replacement
  1. Lenovo Yoga 710-11ISK Speaker Replacement, Speaker: step 1, image 1 of 1
    • Remove the 11 screws located on the back panel using a T5 Torx screwdriver.
  2. Lenovo Yoga 710-11ISK Speaker Replacement: step 2, image 1 of 1
    • Insert an opening tool between the bottom panel and chassis, then pry around the entire perimeter until the five clips detach, releasing the bottom panel.
  3. Lenovo Yoga 710-11ISK Speaker Replacement: step 3, image 1 of 2 Lenovo Yoga 710-11ISK Speaker Replacement: step 3, image 2 of 2
    • Use a Phillips #000 screwdriver to remove the four screws securing the battery.
    • Grip the battery cable connector on both sides of the plug and gently pull it directly from its port.
    • Lift the battery up and out.
  4. Lenovo Yoga 710-11ISK Speaker Replacement: step 4, image 1 of 1
    • Unplug the wire harness on the left side of the computer to disconnect the speakers from the motherboard
    • Remove the white and blue wires from the plastic brackets holding them in place.
  5. Lenovo Yoga 710-11ISK Speaker Replacement: step 5, image 1 of 3 Lenovo Yoga 710-11ISK Speaker Replacement: step 5, image 2 of 3 Lenovo Yoga 710-11ISK Speaker Replacement: step 5, image 3 of 3
    • Carefully remove both speakers and rubber grommets from their mounts.
    • Slide the right speaker underneath the white ribbon wire.
    • Lift the speakers up and out.
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 5
All Time: 90
