Lenovo Yoga 710-14IKB Fan Replacement
Grant Doerksen
Grant Doerksen and 3 other contributors
Last updated on June 23, 2024
5 minutes
Moderate
Introduction
Go to step 1
This guide will teach you how to remove and replace the cooling fan on your Lenovo Yoga laptop.
Parts
Tools
Show more…
  1. Lenovo Yoga 710-14IKB Fan Replacement, Back Cover: step 1, image 1 of 1
    • Ensure your device is completely OFF before starting this guide.
    • Use a Torx T4 screwdriver to unscrew the nine 5 mm screws holding the cover in place.
    • Use a Torx T4 screwdriver to unscrew the 8 mm screw in the center.
    • When, reassembling, make sure not to tighten the screws too much or you may risk cracking the plastic cover.
  2. Lenovo Yoga 710-14IKB Fan Replacement: step 2, image 1 of 3 Lenovo Yoga 710-14IKB Fan Replacement: step 2, image 2 of 3 Lenovo Yoga 710-14IKB Fan Replacement: step 2, image 3 of 3
    • Use the plastic opening tool to pry the cover up and away from the laptop, starting at one end and working your way around the cover.
    • The cover is large and flat and made of thin plastic. It cracks easily, so make sure not to pry too hard.
  3. Lenovo Yoga 710-14IKB Fan Replacement, Fan: step 3, image 1 of 2 Lenovo Yoga 710-14IKB Fan Replacement, Fan: step 3, image 2 of 2
    • Unscrew the the two 4mm Phillips #00 screws holding the fan in place.
    • Be careful not to break the thin plastic tabs on the fan casing.
  4. Lenovo Yoga 710-14IKB Fan Replacement: step 4, image 1 of 2 Lenovo Yoga 710-14IKB Fan Replacement: step 4, image 2 of 2
    • Use your fingernail or a plastic tool to disconnect the fan power cable from the circuit board.
    • Slide it straight out of its socket.
  5. Lenovo Yoga 710-14IKB Fan Replacement: step 5, image 1 of 2 Lenovo Yoga 710-14IKB Fan Replacement: step 5, image 2 of 2
    • Lift the fan up and out of its mount.
    • Be careful that the small plastic tabs don't get snagged on any other parts or cables.
2 other people completed this guide.
Grant Doerksen
1,005 Reputation
5 Guides authored
Cal Poly, Team S14-G5, Banghart Spring 2017 Member of Cal Poly, Team S14-G5, Banghart Spring 2017
CPSU-BANGHART-S17S14G5
4 Members
27 Guides authored
4 Comments
Thanks for a great guide! This is a great laptop with a really noisy cheep fan... It makes a high pitch sound even under the low load. Is it possible to make it run any better??
k.kubaitis - Reply
I have searched online for a replacement fan for the Yoga 710-14ikb but havent found any. Is it possible to use a fan for another model, perhaps the 14isk or 15ikb?
David Hansson - Reply
I did find this but dont want to wait that long. https://www.aliexpress.com/item/New-lapt...
edwardrmorley -
does anyone know the best place to buy a new one of these fans?
edwardrmorley - Reply
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 33
All Time: 3,619
