Lenovo Yoga 710-14IKB RAM Replacement
  1. Lenovo Yoga 710-14IKB RAM Replacement, Back Cover: step 1, image 1 of 1
    • Ensure your device is completely OFF before starting this guide.
    • Use a Torx T4 screwdriver to unscrew the nine 5 mm screws holding the cover in place.
    • Use a Torx T4 screwdriver to unscrew the 8 mm screw in the center.
    • When, reassembling, make sure not to tighten the screws too much or you may risk cracking the plastic cover.
  2. Lenovo Yoga 710-14IKB RAM Replacement: step 2, image 1 of 3 Lenovo Yoga 710-14IKB RAM Replacement: step 2, image 2 of 3 Lenovo Yoga 710-14IKB RAM Replacement: step 2, image 3 of 3
    • Use the plastic opening tool to pry the cover up and away from the laptop, starting at one end and working your way around the cover.
    • The cover is large and flat and made of thin plastic. It cracks easily, so make sure not to pry too hard.
  3. Lenovo Yoga 710-14IKB RAM Replacement, RAM: step 3, image 1 of 2 Lenovo Yoga 710-14IKB RAM Replacement, RAM: step 3, image 2 of 2
    • Use blue plastic opening tool to pry the ram cover loose. Carefully lift up the ram cover and remove it from the laptop.
  4. Lenovo Yoga 710-14IKB RAM Replacement: step 4, image 1 of 2 Lenovo Yoga 710-14IKB RAM Replacement: step 4, image 2 of 2
    • Locate the ram hold downs.
    • Push outwards on the hold downs to release the RAM.
  5. Lenovo Yoga 710-14IKB RAM Replacement: step 5, image 1 of 2 Lenovo Yoga 710-14IKB RAM Replacement: step 5, image 2 of 2
    • Remove the RAM by pulling away from the RAM socket.
14 other people completed this guide.
Grant Doerksen
1,005 Reputation
5 Guides authored
Cal Poly, Team S14-G5, Banghart Spring 2017 Member of Cal Poly, Team S14-G5, Banghart Spring 2017
CPSU-BANGHART-S17S14G5
4 Members
27 Guides authored
4 Comments
Hi, can the RAM be expandable and what is the highest RAM expansion this lenovo YOGA 710-14IKB can take?
victoria - Reply
Hi Victoria, I replaced the 8GB RAM stick with a single 16GB RAM stick and this does work!
Johannes de Wit -
una pregunta, cuantas ranuras de memoria RAM tiene?
One question, how many RAM slots does it have?
andres arce - Reply
It has 1 RAM slot
Lil Youman -
Past 24 Hours: 1
Past 7 Days: 17
Past 30 Days: 58
All Time: 7,127
