Lenovo Yoga 710-15IKB Battery Replacement
  1. Lenovo Yoga 710-15IKB Battery Replacement, Battery: step 1, image 1 of 1
    • Ensure your computer is completely OFF before starting this guide.
    • Remove the ten 3.3 mm T5 screws from the base cover.
    • The screws aren't all the same length. Be sure to keep the screws sorted as you work.
  2. Lenovo Yoga 710-15IKB Battery Replacement: step 2, image 1 of 1
    • Slide an opening tool between the base and back cover and work your way around the entire device to release the back cover.
  3. Lenovo Yoga 710-15IKB Battery Replacement: step 3, image 1 of 1
    • Lift and remove the back cover.
  4. Lenovo Yoga 710-15IKB Battery Replacement: step 4, image 1 of 1
    • Remove the four 3.5 mm screws around the battery using a Phillips #1 screwdriver.
  5. Lenovo Yoga 710-15IKB Battery Replacement: step 5, image 1 of 1
    Tool used on this step:
    Buy
    • Disconnect the battery by pulling its cable away from the hinge with a pair of tweezers or your fingers.
  6. Lenovo Yoga 710-15IKB Battery Replacement: step 6, image 1 of 1
    • Gently lift and remove the battery.
16 other people completed this guide.
Stephanie Alexander
757 Reputation
3 Guides authored
2 Comments
I had to use a PH000 screwdriver and was only able to remove 1 of the battery screws from the original Lenovo battery. Any suggestions on how to remove the others? Where can I get replacement screws?
karenosickey - Reply
The battery cable requires a lot of force to disconnect; tweezers won't cut it. It's also difficult to reconnect the battery. I used two pairs of needle-nose pliers to squeeze the connector into the socket on both sides.
jkvmyxud - Reply
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 52
All Time: 19,253
