Lenovo Yoga 710-15IKB Fan Replacement
  1. Lenovo Yoga 710-15IKB Fan  Replacement, Battery: step 1, image 1 of 1
    • Ensure your computer is completely OFF before starting this guide.
    • Remove the ten 3.3 mm T5 screws from the base cover.
    • The screws aren't all the same length. Be sure to keep the screws sorted as you work.
  2. Lenovo Yoga 710-15IKB Fan  Replacement: step 2, image 1 of 1
    • Slide an opening tool between the base and back cover and work your way around the entire device to release the back cover.
  3. Lenovo Yoga 710-15IKB Fan  Replacement: step 3, image 1 of 1
    • Lift and remove the back cover.
  4. Lenovo Yoga 710-15IKB Fan  Replacement: step 4, image 1 of 1
    • Remove the four 3.5 mm screws around the battery using a Phillips #1 screwdriver.
  5. Lenovo Yoga 710-15IKB Fan  Replacement: step 5, image 1 of 1
    Tool used on this step:
    Buy
    • Disconnect the battery by pulling its cable away from the hinge with a pair of tweezers or your fingers.
  6. Lenovo Yoga 710-15IKB Fan  Replacement: step 6, image 1 of 1
    • Gently lift and remove the battery.
  7. Lenovo Yoga 710-15IKB Fan  Replacement, Fan: step 7, image 1 of 1
    Buy
    • Use tweezers to grab the fan harness.
    • Gently pull the harness to disconnect from motherboard.
  8. Lenovo Yoga 710-15IKB Fan  Replacement: step 8, image 1 of 1
    • Use a Phillips #1 screwdriver to remove the four screws holding down the fans.
Stephanie Alexander
757 Reputation
3 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 17
All Time: 2,174
