Lenovo Yoga 710-15IKB Solid State Drive Replacement
  1. Lenovo Yoga 710-15IKB Solid State Drive Replacement, Battery: step 1, image 1 of 1
    • Ensure your computer is completely OFF before starting this guide.
    • Remove the ten 3.3 mm T5 screws from the base cover.
    • The screws aren't all the same length. Be sure to keep the screws sorted as you work.
  2. Lenovo Yoga 710-15IKB Solid State Drive Replacement: step 2, image 1 of 1
    • Slide an opening tool between the base and back cover and work your way around the entire device to release the back cover.
  3. Lenovo Yoga 710-15IKB Solid State Drive Replacement: step 3, image 1 of 1
    • Lift and remove the back cover.
  4. Lenovo Yoga 710-15IKB Solid State Drive Replacement: step 4, image 1 of 1
    • Remove the four 3.5 mm screws around the battery using a Phillips #1 screwdriver.
  5. Lenovo Yoga 710-15IKB Solid State Drive Replacement: step 5, image 1 of 1
    Tool used on this step:
    Buy
    • Disconnect the battery by pulling its cable away from the hinge with a pair of tweezers or your fingers.
  6. Lenovo Yoga 710-15IKB Solid State Drive Replacement: step 6, image 1 of 1
    • Gently lift and remove the battery.
  7. Lenovo Yoga 710-15IKB Solid State Drive Replacement, Solid State Drive: step 7, image 1 of 1
    • Remove the one JIS 1 screw holding the solid state drive in place.
  8. Lenovo Yoga 710-15IKB Solid State Drive Replacement: step 8, image 1 of 1
    • Gently pull the solid state drive out and up to remove it from the connector.
3 other people completed this guide.
Andrew Keenan
173 Reputation
1 Guide authored
One Comment
No need to remove battery. No need for tweezers.
Shane Whittet - Reply
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 33
All Time: 7,064
