Lenovo Yoga 710-15IKB Trackpad Replacement
  1. Lenovo Yoga 710-15IKB Trackpad Replacement, Trackpad: step 1, image 1 of 1
    • Remove the ten 3.3 mm screws from the base cover using the T5 Torx screwdriver.
  2. Lenovo Yoga 710-15IKB Trackpad Replacement: step 2, image 1 of 1
    • Slide opening tool between the base and back cover.
  3. Lenovo Yoga 710-15IKB Trackpad Replacement: step 3, image 1 of 1
    • Lift back cover.
  4. Lenovo Yoga 710-15IKB Trackpad Replacement: step 4, image 1 of 1
    • Remove the four 3.5 mm screws around the battery using the Phillips 00 screwdriver.
  5. Lenovo Yoga 710-15IKB Trackpad Replacement: step 5, image 1 of 1
    • Disconnect the battery from the motherboard.
  6. Lenovo Yoga 710-15IKB Trackpad Replacement: step 6, image 1 of 1
    • Lift battery up gently to remove.
  7. Lenovo Yoga 710-15IKB Trackpad Replacement: step 7, image 1 of 1
    • Use the JIS 1 screwdriver bit to unscrew the 3 screws.
  8. Lenovo Yoga 710-15IKB Trackpad Replacement: step 8, image 1 of 1
    • Grip the tab firmly.
  9. Lenovo Yoga 710-15IKB Trackpad Replacement: step 9, image 1 of 1
    • Pull tab until it disconnects from the trackpad. Be gentle - you do not want to damage any part of the tab.
  10. Lenovo Yoga 710-15IKB Trackpad Replacement: step 10, image 1 of 1
    Tool used on this step:
    $3.99
    Buy
  11. Lenovo Yoga 710-15IKB Trackpad Replacement: step 11, image 1 of 1
    • Push the trackpad to remove it.
5 other people completed this guide.
Hanna Deon
245 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 16
All Time: 3,285
