Lenovo Yoga 710-15ISK RAM Replacement
  1. Lenovo Yoga 710-15ISK RAM Replacement, Back Cover: step 1, image 1 of 2 Lenovo Yoga 710-15ISK RAM Replacement, Back Cover: step 1, image 2 of 2
    • Flip your laptop over so the bottom is facing upwards.
    • Remove ten 2 mm screws securing the back cover to the laptop using a Phillips #0 screwdriver. The location of the screws is encircled in the photo.
  2. Lenovo Yoga 710-15ISK RAM Replacement: step 2, image 1 of 1
    • Gently remove the back cover of the laptop with your fingers.
  3. Lenovo Yoga 710-15ISK RAM Replacement, RAM: step 3, image 1 of 2 Lenovo Yoga 710-15ISK RAM Replacement, RAM: step 3, image 2 of 2
    • Use the spudger to detach the clips holding the RAM cover.
    • Gently pry the RAM cover up off of the motherboard using the spudger.
  4. Lenovo Yoga 710-15ISK RAM Replacement: step 4, image 1 of 3 Lenovo Yoga 710-15ISK RAM Replacement: step 4, image 2 of 3 Lenovo Yoga 710-15ISK RAM Replacement: step 4, image 3 of 3
    • Use your fingers to take apart the clips holding the RAM in place.
    • Carefully slide the RAM out of its slot.
Congratulations! You’ve successfully replaced the RAM in your Lenovo Yoga 710-15ISK. Enjoy the enhanced performance, whether for multitasking or demanding applications. If you encounter issues, refer to your laptop’s manual or seek professional assistance.
Elisa Normand
423 Reputation
4 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 3
All Time: 433
