Lenovo Yoga 720-12IKB Headphone Jack Replacement
  1. Lenovo Yoga 720-12IKB Headphone Jack Replacement, Battery: step 1, image 1 of 1
    • Unscrew and remove the four 5.5 mm Phillips #00 screws on the back panel.
  2. Lenovo Yoga 720-12IKB Headphone Jack Replacement: step 2, image 1 of 1
    • Pull down on the cover to remove it and you will see the battery after removing the cover.
  3. Lenovo Yoga 720-12IKB Headphone Jack Replacement: step 3, image 1 of 2 Lenovo Yoga 720-12IKB Headphone Jack Replacement: step 3, image 2 of 2
    • Unscrew and remove the 4.0 mm Phillips #00 screws on the battery to remove it from the motherboard.
  4. Lenovo Yoga 720-12IKB Headphone Jack Replacement: step 4, image 1 of 2 Lenovo Yoga 720-12IKB Headphone Jack Replacement: step 4, image 2 of 2
    • Remove the battery wires from the socket on the motherboard above the battery.
  5. Lenovo Yoga 720-12IKB Headphone Jack Replacement: step 5, image 1 of 1
    • Finally remove the battery from the case.
  6. Lenovo Yoga 720-12IKB Headphone Jack Replacement, Headphone Jack: step 6, image 1 of 1
    • The headphone jack can be found on the top right of the chassis.
    • Start by removing the 2.0 mm Phillips #00 screw.
  7. Lenovo Yoga 720-12IKB Headphone Jack Replacement: step 7, image 1 of 1
    • Undo the clip and remove the connector.
  8. Lenovo Yoga 720-12IKB Headphone Jack Replacement: step 8, image 1 of 1
    • Pull the connector to the right to remove it from the clip.
  9. Lenovo Yoga 720-12IKB Headphone Jack Replacement: step 9, image 1 of 1
    • Remove the headphone jack from the chassis.
Alex Escobar
778 Reputation
6 Guides authored
Gateway, Team 1-4, Pee Spring 2022 Member of Gateway, Team 1-4, Pee Spring 2022
GCC-PEE-S22S1G4
3 Members
6 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 7
All Time: 224
