Lenovo Yoga 720-12IKB Wireless LAN Card Replacement
  1. Lenovo Yoga 720-12IKB Wireless LAN Card Replacement, Battery: step 1, image 1 of 1
    • Unscrew and remove the four 5.5 mm Phillips #00 screws on the back panel.
  2. Lenovo Yoga 720-12IKB Wireless LAN Card Replacement: step 2, image 1 of 1
    • Pull down on the cover to remove it and you will see the battery after removing the cover.
  3. Lenovo Yoga 720-12IKB Wireless LAN Card Replacement: step 3, image 1 of 2 Lenovo Yoga 720-12IKB Wireless LAN Card Replacement: step 3, image 2 of 2
    • Unscrew and remove the 4.0 mm Phillips #00 screws on the battery to remove it from the motherboard.
  4. Lenovo Yoga 720-12IKB Wireless LAN Card Replacement: step 4, image 1 of 2 Lenovo Yoga 720-12IKB Wireless LAN Card Replacement: step 4, image 2 of 2
    • Remove the battery wires from the socket on the motherboard above the battery.
  5. Lenovo Yoga 720-12IKB Wireless LAN Card Replacement: step 5, image 1 of 1
    • Finally remove the battery from the case.
  6. Lenovo Yoga 720-12IKB Wireless LAN Card Replacement, Wireless LAN Card: step 6, image 1 of 1
    • On the top right of the system you will find the wireless LAN card. Remove the 3.0 mm Phillips #00 screw.
  7. Lenovo Yoga 720-12IKB Wireless LAN Card Replacement: step 7, image 1 of 2 Lenovo Yoga 720-12IKB Wireless LAN Card Replacement: step 7, image 2 of 2
    • Disconnect both wireless LAN cables by pulling up.
  8. Lenovo Yoga 720-12IKB Wireless LAN Card Replacement: step 8, image 1 of 1
    • Lift the wireless LAN card up and pull out.
  9. Lenovo Yoga 720-12IKB Wireless LAN Card Replacement: step 9, image 1 of 1
    • You can now replace the wireless LAN card.
Alex Escobar
778 Reputation
6 Guides authored
Gateway, Team 1-4, Pee Spring 2022 Member of Gateway, Team 1-4, Pee Spring 2022
GCC-PEE-S22S1G4
3 Members
6 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 9
All Time: 148
