Introduction
It is important that your Lenovo Yoga 720-13IKB’s fan is running efficiently because it is essential to the cooling system that maintains proper laptop functionality. Over time, a laptop’s fan can accumulate dust or experience wear which typically results in the fan lasting for around three years on the lower estimates. Some symptoms that might warrant a fan replacement include abnormally loud fan noises, performance problems, overheating, and abrupt changes in fan speeds. This guide will provide steps to replacing your fan, which will aid in maintaining your laptop’s performance.
Remove seven Torx T5 short screws.
Remove three Torx T5 long screws.
Use a JIS #000 screwdriver to unscrew and remove the seven 2.5mm screws that secure the fan to the motherboard.
Remove the fan from the laptop.
