Lenovo Yoga 720-15IKB Bottom Cover Replacement
  1. Lenovo Yoga 720-15IKB Bottom Cover Replacement, Bottom Cover: step 1, image 1 of 3 Lenovo Yoga 720-15IKB Bottom Cover Replacement, Bottom Cover: step 1, image 2 of 3 Lenovo Yoga 720-15IKB Bottom Cover Replacement, Bottom Cover: step 1, image 3 of 3
    • Power off the device before starting.
    • Flip the device over with the hinges facing away from you.
    • Remove seven 5.0 mm Torx T5 screws.
    • Remove three 9.5 mm Torx T5 screws.
  2. Lenovo Yoga 720-15IKB Bottom Cover Replacement: step 2, image 1 of 2 Lenovo Yoga 720-15IKB Bottom Cover Replacement: step 2, image 2 of 2
    • Pry around the edges from one side to another with a plastic opening tool.
    • Do not pry on the side with the hinges because this can break the cover.
    • Lift the case from the front until you feel resistance.
    • Do not keep lifting after you feel resistance, or the bottom cover can break.
    • Pull the cover towards you, away from the hinges.
    • Completely lift off the cover.
Joshua von Damm
137 Reputation
1 Guide authored
Cal Poly, Team S19-G3, White Winter 2020 Member of Cal Poly, Team S19-G3, White Winter 2020
CPSU-WHITE-W20S19G3
4 Members
25 Guides authored
0 Comments
Past 24 Hours: 3
Past 7 Days: 4
Past 30 Days: 17
All Time: 1,828
