Lenovo Yoga 720-15IKB Speakers Replacement
  1. Lenovo Yoga 720-15IKB Speakers Replacement, Bottom Cover: step 1, image 1 of 3 Lenovo Yoga 720-15IKB Speakers Replacement, Bottom Cover: step 1, image 2 of 3 Lenovo Yoga 720-15IKB Speakers Replacement, Bottom Cover: step 1, image 3 of 3
    • Power off the device before starting.
    • Flip the device over with the hinges facing away from you.
    • Remove seven 5.0 mm Torx T5 screws.
    • Remove three 9.5 mm Torx T5 screws.
  2. Lenovo Yoga 720-15IKB Speakers Replacement: step 2, image 1 of 2 Lenovo Yoga 720-15IKB Speakers Replacement: step 2, image 2 of 2
    • Pry around the edges from one side to another with a plastic opening tool.
    • Do not pry on the side with the hinges because this can break the cover.
    • Lift the case from the front until you feel resistance.
    • Do not keep lifting after you feel resistance, or the bottom cover can break.
    • Pull the cover towards you, away from the hinges.
    • Completely lift off the cover.
  3. Lenovo Yoga 720-15IKB Speakers Replacement, Speakers: step 3, image 1 of 3 Lenovo Yoga 720-15IKB Speakers Replacement, Speakers: step 3, image 2 of 3 Lenovo Yoga 720-15IKB Speakers Replacement, Speakers: step 3, image 3 of 3
    • Here are the speakers for this device.
    • Pull the right speaker straight up and remove it from the computer.
    • As you remove the speaker, make sure to also carefully pull the wire connected to the speaker out along with the speaker.
  4. Lenovo Yoga 720-15IKB Speakers Replacement: step 4, image 1 of 1
    • Remove the left speaker similarly to how the right speaker was removed.
  5. Lenovo Yoga 720-15IKB Speakers Replacement: step 5, image 1 of 1
    • Unplug the speaker by firmly pulling the wire out of the socket.
Jeremy Kostel
249 Reputation
2 Guides authored
Cal Poly, Team S19-G3, White Winter 2020 Member of Cal Poly, Team S19-G3, White Winter 2020
CPSU-WHITE-W20S19G3
4 Members
25 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 3
All Time: 426
