Lenovo Yoga 720-15IKB Wireless Adapter Replacement
  1. Lenovo Yoga 720-15IKB Wireless Adapter Replacement, Bottom Cover: step 1, image 1 of 3 Lenovo Yoga 720-15IKB Wireless Adapter Replacement, Bottom Cover: step 1, image 2 of 3 Lenovo Yoga 720-15IKB Wireless Adapter Replacement, Bottom Cover: step 1, image 3 of 3
    • Power off the device before starting.
    • Flip the device over with the hinges facing away from you.
    • Remove seven 5.0 mm Torx T5 screws.
    • Remove three 9.5 mm Torx T5 screws.
  2. Lenovo Yoga 720-15IKB Wireless Adapter Replacement: step 2, image 1 of 2 Lenovo Yoga 720-15IKB Wireless Adapter Replacement: step 2, image 2 of 2
    • Pry around the edges from one side to another with a plastic opening tool.
    • Do not pry on the side with the hinges because this can break the cover.
    • Lift the case from the front until you feel resistance.
    • Do not keep lifting after you feel resistance, or the bottom cover can break.
    • Pull the cover towards you, away from the hinges.
    • Completely lift off the cover.
  3. Lenovo Yoga 720-15IKB Wireless Adapter Replacement, Wireless Adapter: step 3, image 1 of 3 Lenovo Yoga 720-15IKB Wireless Adapter Replacement, Wireless Adapter: step 3, image 2 of 3 Lenovo Yoga 720-15IKB Wireless Adapter Replacement, Wireless Adapter: step 3, image 3 of 3
    • Lift the foam covering the connecting wires and screw, and use the Phillips #0 screwdriver to remove the 2mm screw.
  4. Lenovo Yoga 720-15IKB Wireless Adapter Replacement: step 4, image 1 of 1
    • Grab the adapter from both sides and pull towards the hinge to remove the adapter from the device.
  5. Lenovo Yoga 720-15IKB Wireless Adapter Replacement: step 5, image 1 of 1
    • Remove the black and white wires from the adapter by pulling up on each wire.
    • When reassembling, make sure to press each wire connector firmly onto the new adapter to make sure it is a secure fit.
Matthew Bornhorst
495 Reputation
2 Guides authored
Cal Poly, Team S19-G3, White Winter 2020 Member of Cal Poly, Team S19-G3, White Winter 2020
CPSU-WHITE-W20S19G3
4 Members
25 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 11
All Time: 783
