Lenovo Yoga 900-13ISK Hinge Assembly Replacement
  1. Lenovo Yoga 900-13ISK Hinge Assembly Replacement, Back Cover: step 1, image 1 of 2 Lenovo Yoga 900-13ISK Hinge Assembly Replacement, Back Cover: step 1, image 2 of 2
    • Using a T5 Torx screwdriver, remove the ten 5.5 mm screws from the back case of the laptop.
  2. Lenovo Yoga 900-13ISK Hinge Assembly Replacement: step 2, image 1 of 3 Lenovo Yoga 900-13ISK Hinge Assembly Replacement: step 2, image 2 of 3 Lenovo Yoga 900-13ISK Hinge Assembly Replacement: step 2, image 3 of 3
    • Use a spudger to pry open the back case at the hinges of the laptop.
    • There are plastic clips around the perimeter of the case holding down the back cover. These will need to be popped off as the cover is removed.
    • Use your fingers to completely pop off the back cover.
  3. Lenovo Yoga 900-13ISK Hinge Assembly Replacement, Battery: step 3, image 1 of 3 Lenovo Yoga 900-13ISK Hinge Assembly Replacement, Battery: step 3, image 2 of 3 Lenovo Yoga 900-13ISK Hinge Assembly Replacement, Battery: step 3, image 3 of 3
    • Remove the five 3.6 mm screws from the battery with a Phillips #00 screwdriver.
  4. Lenovo Yoga 900-13ISK Hinge Assembly Replacement: step 4, image 1 of 3 Lenovo Yoga 900-13ISK Hinge Assembly Replacement: step 4, image 2 of 3 Lenovo Yoga 900-13ISK Hinge Assembly Replacement: step 4, image 3 of 3
    • Grab the bottom corners of the battery and gently pull the battery until the cable disconnects from the connector on the motherboard.
    • While reassembling, use a plastic spudger to push the battery cable into the connector on the underside of the motherboard. This will be easier to do before the screws are replaced.
  5. Lenovo Yoga 900-13ISK Hinge Assembly Replacement, Display Assembly: step 5, image 1 of 3 Lenovo Yoga 900-13ISK Hinge Assembly Replacement, Display Assembly: step 5, image 2 of 3 Lenovo Yoga 900-13ISK Hinge Assembly Replacement, Display Assembly: step 5, image 3 of 3
    • Remove the ten 3.6 mm screws from the hinge bracket with a Phillips #00 screwdriver.
  6. Lenovo Yoga 900-13ISK Hinge Assembly Replacement: step 6, image 1 of 3 Lenovo Yoga 900-13ISK Hinge Assembly Replacement: step 6, image 2 of 3 Lenovo Yoga 900-13ISK Hinge Assembly Replacement: step 6, image 3 of 3
    • Use the pointed end of a spudger to lift the hinged locking flap of the display ZIF connector.
  7. Lenovo Yoga 900-13ISK Hinge Assembly Replacement: step 7, image 1 of 2 Lenovo Yoga 900-13ISK Hinge Assembly Replacement: step 7, image 2 of 2
    Tool used on this step:
    Buy
    • Pull out the display cable with a pair of blunt nose tweezers.
  8. Lenovo Yoga 900-13ISK Hinge Assembly Replacement: step 8, image 1 of 3 Lenovo Yoga 900-13ISK Hinge Assembly Replacement: step 8, image 2 of 3 Lenovo Yoga 900-13ISK Hinge Assembly Replacement: step 8, image 3 of 3
    • Open the laptop to a 45° angle, then close the laptop.
    • This raises the hinge, which will stay open as the bottom case is lowered.
  9. Lenovo Yoga 900-13ISK Hinge Assembly Replacement: step 9, image 1 of 3 Lenovo Yoga 900-13ISK Hinge Assembly Replacement: step 9, image 2 of 3 Lenovo Yoga 900-13ISK Hinge Assembly Replacement: step 9, image 3 of 3
    • Slide the bottom case away from the hinge.
    • If the hinge is catching on the case, either go back to the previous step and open the case a bit more, or manually open the hinge with your fingers.
  10. Careful: steps 10-16 are sourced from a guide that's marked as in-progress.
    Lenovo Yoga 900-13ISK Hinge Assembly Replacement, Display Opening Prereq: step 10, image 1 of 1
    • Apply heat along the bottom and left edges of the screen, either with a heat gun or iOpener.
    • Check out our iOpener Instructions if you need help!
  11. Lenovo Yoga 900-13ISK Hinge Assembly Replacement: step 11, image 1 of 2 Lenovo Yoga 900-13ISK Hinge Assembly Replacement: step 11, image 2 of 2
    • Insert an opening pick into the corner of the screen and slide it around slightly to create an opening.
  12. Lenovo Yoga 900-13ISK Hinge Assembly Replacement: step 12, image 1 of 3 Lenovo Yoga 900-13ISK Hinge Assembly Replacement: step 12, image 2 of 3 Lenovo Yoga 900-13ISK Hinge Assembly Replacement: step 12, image 3 of 3
    • Insert a second opening pick and slide it along the side of the display, cutting away the adhesive.
  13. Lenovo Yoga 900-13ISK Hinge Assembly Replacement: step 13, image 1 of 1
    • Use a heat gun or iOpener to apply heat to the top and side edge that have not yet been opened.
  14. Lenovo Yoga 900-13ISK Hinge Assembly Replacement: step 14, image 1 of 3 Lenovo Yoga 900-13ISK Hinge Assembly Replacement: step 14, image 2 of 3 Lenovo Yoga 900-13ISK Hinge Assembly Replacement: step 14, image 3 of 3
    • Continue cutting away the adhesive on the top and side edges of the display.
  15. Lenovo Yoga 900-13ISK Hinge Assembly Replacement: step 15, image 1 of 3 Lenovo Yoga 900-13ISK Hinge Assembly Replacement: step 15, image 2 of 3 Lenovo Yoga 900-13ISK Hinge Assembly Replacement: step 15, image 3 of 3
    • Open the display casing along the top edge.
  16. Lenovo Yoga 900-13ISK Hinge Assembly Replacement: step 16, image 1 of 3 Lenovo Yoga 900-13ISK Hinge Assembly Replacement: step 16, image 2 of 3 Lenovo Yoga 900-13ISK Hinge Assembly Replacement: step 16, image 3 of 3
    • Pull the display cable out from the hinge mechanism.
  17. Lenovo Yoga 900-13ISK Hinge Assembly Replacement, Hinge Assembly: step 17, image 1 of 3 Lenovo Yoga 900-13ISK Hinge Assembly Replacement, Hinge Assembly: step 17, image 2 of 3 Lenovo Yoga 900-13ISK Hinge Assembly Replacement, Hinge Assembly: step 17, image 3 of 3
    • Remove the ten 2.3 mm screws from the hinge assembly with a Phillips #00 screwdriver.
    • Remove the single 2.2 mm screw from the hinge assembly with a Phillips #00 screwdriver.
    • This screw has a smaller head from the rest if you have trouble distinguishing it from the rest during reassembly.
  18. Lenovo Yoga 900-13ISK Hinge Assembly Replacement: step 18, image 1 of 1
    • Lift off the hinge assembly.
Austin Blakely
19,855 Reputation
53 Guides authored
iFixit Member of iFixit
Staff
141 Members
17,895 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 6
All Time: 345
