Lenovo Yoga 900-13ISK Left Daughterboard Replacement
  1. Lenovo Yoga 900-13ISK Left Daughterboard Replacement, Back Cover: step 1, image 1 of 2 Lenovo Yoga 900-13ISK Left Daughterboard Replacement, Back Cover: step 1, image 2 of 2
    • Using a T5 Torx screwdriver, remove the ten 5.5 mm screws from the back case of the laptop.
  2. Lenovo Yoga 900-13ISK Left Daughterboard Replacement: step 2, image 1 of 3 Lenovo Yoga 900-13ISK Left Daughterboard Replacement: step 2, image 2 of 3 Lenovo Yoga 900-13ISK Left Daughterboard Replacement: step 2, image 3 of 3
    • Use a spudger to pry open the back case at the hinges of the laptop.
    • There are plastic clips around the perimeter of the case holding down the back cover. These will need to be popped off as the cover is removed.
    • Use your fingers to completely pop off the back cover.
  3. Lenovo Yoga 900-13ISK Left Daughterboard Replacement, Battery: step 3, image 1 of 3 Lenovo Yoga 900-13ISK Left Daughterboard Replacement, Battery: step 3, image 2 of 3 Lenovo Yoga 900-13ISK Left Daughterboard Replacement, Battery: step 3, image 3 of 3
    • Remove the five 3.6 mm screws from the battery with a Phillips #00 screwdriver.
  4. Lenovo Yoga 900-13ISK Left Daughterboard Replacement: step 4, image 1 of 3 Lenovo Yoga 900-13ISK Left Daughterboard Replacement: step 4, image 2 of 3 Lenovo Yoga 900-13ISK Left Daughterboard Replacement: step 4, image 3 of 3
    • Grab the bottom corners of the battery and gently pull the battery until the cable disconnects from the connector on the motherboard.
    • While reassembling, use a plastic spudger to push the battery cable into the connector on the underside of the motherboard. This will be easier to do before the screws are replaced.
  5. Lenovo Yoga 900-13ISK Left Daughterboard Replacement, Left Daughterboard: step 5, image 1 of 3 Lenovo Yoga 900-13ISK Left Daughterboard Replacement, Left Daughterboard: step 5, image 2 of 3 Lenovo Yoga 900-13ISK Left Daughterboard Replacement, Left Daughterboard: step 5, image 3 of 3
    • Remove the single 3.6 mm screw from the daughterboard with a Phillips #00 screwdriver.
  6. Lenovo Yoga 900-13ISK Left Daughterboard Replacement: step 6, image 1 of 3 Lenovo Yoga 900-13ISK Left Daughterboard Replacement: step 6, image 2 of 3 Lenovo Yoga 900-13ISK Left Daughterboard Replacement: step 6, image 3 of 3
    • Grabbing the outside edge of the daughterboard, flip the board up to reveal the ZIF connector on the underside.
  7. Lenovo Yoga 900-13ISK Left Daughterboard Replacement: step 7, image 1 of 3 Lenovo Yoga 900-13ISK Left Daughterboard Replacement: step 7, image 2 of 3 Lenovo Yoga 900-13ISK Left Daughterboard Replacement: step 7, image 3 of 3
    • Using a spudger, flip up the hinged locking tab of the ZIF connector on the underside of the daughterboard.
    • Pull the daughterboard away from the cable to disconnect.
Austin Blakely
19,855 Reputation
53 Guides authored
iFixit Member of iFixit
Staff
141 Members
17,895 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 9
All Time: 421
