Lenovo Yoga 910-13IKB Motherboard Replacement
  1. Lenovo Yoga 910-13IKB Motherboard Replacement, Back Panel: step 1, image 1 of 2 Lenovo Yoga 910-13IKB Motherboard Replacement, Back Panel: step 1, image 2 of 2
    • Turn the laptop over and remove the ten Torx T5 screws along the perimeter of the bottom panel using the T5 Torx Screwdriver.
    • Remove the back panel from the device exposing the components.
  2. Lenovo Yoga 910-13IKB Motherboard Replacement, Battery: step 2, image 1 of 1
    • Remove the four 3 mm Phillips #0 screws holding the battery in place.
  3. Lenovo Yoga 910-13IKB Motherboard Replacement: step 3, image 1 of 3 Lenovo Yoga 910-13IKB Motherboard Replacement: step 3, image 2 of 3 Lenovo Yoga 910-13IKB Motherboard Replacement: step 3, image 3 of 3
    • Disconnect the battery cable from its motherboard socket by gently pulling it towards the battery. The spudger tool may be needed to lift the flap seal.
    • Pull parallel to the battery, not straight up.
    • Pull evenly on the width of the cable so that no individual wire is overly strained.
    • Lift the battery out.
  4. Lenovo Yoga 910-13IKB Motherboard Replacement, Trackpad: step 4, image 1 of 3 Lenovo Yoga 910-13IKB Motherboard Replacement, Trackpad: step 4, image 2 of 3 Lenovo Yoga 910-13IKB Motherboard Replacement, Trackpad: step 4, image 3 of 3
    • Using the Phillips #0 screwdriver, remove all six screws holding the trackpad to the device.
    • Find the ribbon cable, the black bundle of wires attached to the trackpad, and lift the head of the ribbon cable towards you.
    • Carefully lift up the trackpad and remove it from the device.
  5. Lenovo Yoga 910-13IKB Motherboard Replacement, Motherboard: step 5, image 1 of 3 Lenovo Yoga 910-13IKB Motherboard Replacement, Motherboard: step 5, image 2 of 3 Lenovo Yoga 910-13IKB Motherboard Replacement, Motherboard: step 5, image 3 of 3
    • Remove the screws attached to the USB ports on both sides of the device with a Phillips #0 screwdriver.
    • Detach both of the ribbon cables attached to each USB port with a wedge device, then detach the USB ports.
  6. Lenovo Yoga 910-13IKB Motherboard Replacement: step 6, image 1 of 3 Lenovo Yoga 910-13IKB Motherboard Replacement: step 6, image 2 of 3 Lenovo Yoga 910-13IKB Motherboard Replacement: step 6, image 3 of 3
    • Remove the screws attached to the SSD stick with a Phillips #0 screwdriver.
    • Pull the SSD stick directly to the right until it shifts out of place to remove it.
    • Storage chip above it (further away from you) may also be detached by pulling it directly to the right until it clicks out.
  7. Lenovo Yoga 910-13IKB Motherboard Replacement: step 7, image 1 of 2 Lenovo Yoga 910-13IKB Motherboard Replacement: step 7, image 2 of 2
    • Remove the four screws attached to both fans, and the back connector strip (the long metal piece furthest from you with screws in it) with a Phillips #0 screwdriver.
  8. Lenovo Yoga 910-13IKB Motherboard Replacement: step 8, image 1 of 3 Lenovo Yoga 910-13IKB Motherboard Replacement: step 8, image 2 of 3 Lenovo Yoga 910-13IKB Motherboard Replacement: step 8, image 3 of 3
    • Remove the screws attached to the motherboard with a Phillips #0 screwdriver.
    • Remove the back connector strip using a spudger or plastic opening tool to pry it off of the device.
    • With the back connector strip removed, pry the motherboard up and off of the device.
3 other people completed this guide.
0 Comments
Past 24 Hours: 2
Past 7 Days: 12
Past 30 Days: 41
All Time: 1,896
