Lenovo Yoga 910-13IKB SSD Replacement
  1. Lenovo Yoga 910-13IKB SSD Replacement, Bottom Panel: step 1, image 1 of 2 Lenovo Yoga 910-13IKB SSD Replacement, Bottom Panel: step 1, image 2 of 2
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Turn the laptop over and remove the ten Torx T5 screws along the perimeter of the bottom panel.
    • Remove the panel.
  2. Lenovo Yoga 910-13IKB SSD Replacement: step 2, image 1 of 1
    • Remove all 4 screws attached to the battery with a small Phillips head screwdriver.
    • Each screw on the back is M2 x 1.7mm
    • After the screws are taken out, remove the battery.
  3. Lenovo Yoga 910-13IKB SSD Replacement: step 3, image 1 of 1
    • Remove all 6 screws attached to the trackpad with a small Phillips head screwdriver.
    • Detach the ribbon cable connected to the trackpad using a wedge device.
    • Remove the trackpad using a wedge device
  4. Lenovo Yoga 910-13IKB SSD Replacement: step 4, image 1 of 1
    • Remove all 6 screws attached to the USB ports on both sides of the device with a small Philips head screwdriver.
    • Detach both ribbon cables attached to each USB port with a wedge device, then detach the USB ports.
  5. Lenovo Yoga 910-13IKB SSD Replacement: step 5, image 1 of 3 Lenovo Yoga 910-13IKB SSD Replacement: step 5, image 2 of 3 Lenovo Yoga 910-13IKB SSD Replacement: step 5, image 3 of 3
    • Remove all 4 screws attached to SSD stick with a small Phillips head screwdriver.
    • Pull the SSD stick directly to the right until it shifts out of place to remove it.
    • The storage chip above it (further away from you) may also simply be detached by pulling it directly to the right until it clicks out.
  6. Lenovo Yoga 910-13IKB SSD Replacement: step 6, image 1 of 3 Lenovo Yoga 910-13IKB SSD Replacement: step 6, image 2 of 3 Lenovo Yoga 910-13IKB SSD Replacement: step 6, image 3 of 3
    • Remove all 4 screws attached to both fans, and the back connector strip (long metal piece furthest from you with screws in it) with a small Phillips head screwdriver
    • Remove the back connector strip using a wedge device to pry it off of the device
    • With the back connector strip removed, pry the fans (which are attached) using a wedge device and the fans will now be maintainable.
  7. Lenovo Yoga 910-13IKB SSD Replacement, SSD: step 7, image 1 of 1
    • Remove the 3mm JIS #00 screw holding the storage in place.
  8. Lenovo Yoga 910-13IKB SSD Replacement: step 8, image 1 of 2 Lenovo Yoga 910-13IKB SSD Replacement: step 8, image 2 of 2
    • Pull up lightly on the drive and gently pull it out of the connector.
Nikhil Nagarajan
97 Reputation
1 Guide authored
Cal Poly, Team S1-G5, White Winter 2020 Member of Cal Poly, Team S1-G5, White Winter 2020
CPSU-WHITE-W20S1G5
4 Members
14 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 18
Past 30 Days: 94
All Time: 5,709
