Lenovo Yoga 920-13IKB Audio Jack Replacement
  1. Lenovo Yoga 920-13IKB Audio Jack Replacement, Back Cover: step 1, image 1 of 2 Lenovo Yoga 920-13IKB Audio Jack Replacement, Back Cover: step 1, image 2 of 2
    • Flip the device over to access the screws on the back cover.
    • Remove the ten 5mm Torx T5 screws on the back cover to loosen the back cover.
  2. Lenovo Yoga 920-13IKB Audio Jack Replacement: step 2, image 1 of 3 Lenovo Yoga 920-13IKB Audio Jack Replacement: step 2, image 2 of 3 Lenovo Yoga 920-13IKB Audio Jack Replacement: step 2, image 3 of 3
    • Slide the iFixit Opening Tool under the back cover to lift it up.
    • Pull up on the cover with your hand to release the tab holding the center of the cover in place.
  3. Lenovo Yoga 920-13IKB Audio Jack Replacement, Motherboard: step 3, image 1 of 2 Lenovo Yoga 920-13IKB Audio Jack Replacement, Motherboard: step 3, image 2 of 2
    • Remove the twelve 5mm Phillips #00 screws to loosen the motherboard.
  4. Lenovo Yoga 920-13IKB Audio Jack Replacement: step 4, image 1 of 3 Lenovo Yoga 920-13IKB Audio Jack Replacement: step 4, image 2 of 3 Lenovo Yoga 920-13IKB Audio Jack Replacement: step 4, image 3 of 3
    • Flip up the ten flat connectors holding the motherboard using the iFixit Opening Tool to free the motherboard.
  5. Lenovo Yoga 920-13IKB Audio Jack Replacement: step 5, image 1 of 2 Lenovo Yoga 920-13IKB Audio Jack Replacement: step 5, image 2 of 2
    Tool used on this step:
    Buy
    • Pull out the ribbon cables from the opened connectors using the iFixit Tweezers to free up the motherboard.
  6. Lenovo Yoga 920-13IKB Audio Jack Replacement: step 6, image 1 of 2 Lenovo Yoga 920-13IKB Audio Jack Replacement: step 6, image 2 of 2
    • Disconnect the battery by pulling the ribbon wire grouping out of the top of the motherboard.
  7. Lenovo Yoga 920-13IKB Audio Jack Replacement: step 7, image 1 of 2 Lenovo Yoga 920-13IKB Audio Jack Replacement: step 7, image 2 of 2
    • Disconnect the red and black wire from the motherboard using the iFixit Tweezers.
  8. Lenovo Yoga 920-13IKB Audio Jack Replacement: step 8, image 1 of 3 Lenovo Yoga 920-13IKB Audio Jack Replacement: step 8, image 2 of 3 Lenovo Yoga 920-13IKB Audio Jack Replacement: step 8, image 3 of 3
    • Lift the motherboard up parallel to the hinge of the device.
    • Gently pull away from the port cutouts of the USB-C and audio jack to remove the motherboard from the device casing.
    • Avoid pulling the motherboard all the way out until the green AC card is disconnected.
  9. Lenovo Yoga 920-13IKB Audio Jack Replacement: step 9, image 1 of 3 Lenovo Yoga 920-13IKB Audio Jack Replacement: step 9, image 2 of 3 Lenovo Yoga 920-13IKB Audio Jack Replacement: step 9, image 3 of 3
    • Disconnect the green AC card plugged into the motherboard by pulling it out with your hands.
  10. Lenovo Yoga 920-13IKB Audio Jack Replacement: step 10, image 1 of 1
    • Flip the motherboard over to access the back side.
  11. Lenovo Yoga 920-13IKB Audio Jack Replacement: step 11, image 1 of 3 Lenovo Yoga 920-13IKB Audio Jack Replacement: step 11, image 2 of 3 Lenovo Yoga 920-13IKB Audio Jack Replacement: step 11, image 3 of 3
    • Remove four 3mm JIS #00 screws with the screwdriver.
    • Remove one 3mm Phillips #00 screw with the screwdriver.
    • The screws stay attached to the speaker when removed from the motherboard.
  12. Lenovo Yoga 920-13IKB Audio Jack Replacement: step 12, image 1 of 1
    • Separate the fans from the motherboard to isolate it for replacement.
  13. Lenovo Yoga 920-13IKB Audio Jack Replacement, Audio Jack: step 13, image 1 of 1
    • Replace the motherboard to replace the audio jack.
Alyssa McCulloch
1,990 Reputation
9 Guides authored
Cal Poly, Team S2-G3, White Winter 2019 Member of Cal Poly, Team S2-G3, White Winter 2019
CPSU-WHITE-W19S2G3
4 Members
29 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 873
