Lenovo Yoga 920-13IKB Fingerprint Sensor Replacement
  1. Lenovo Yoga 920-13IKB Fingerprint Sensor Replacement, Back Cover: step 1, image 1 of 2 Lenovo Yoga 920-13IKB Fingerprint Sensor Replacement, Back Cover: step 1, image 2 of 2
    • Flip the device over to access the screws on the back cover.
    • Remove the ten 5mm Torx T5 screws on the back cover to loosen the back cover.
  2. Lenovo Yoga 920-13IKB Fingerprint Sensor Replacement: step 2, image 1 of 3 Lenovo Yoga 920-13IKB Fingerprint Sensor Replacement: step 2, image 2 of 3 Lenovo Yoga 920-13IKB Fingerprint Sensor Replacement: step 2, image 3 of 3
    • Slide the iFixit Opening Tool under the back cover to lift it up.
    • Pull up on the cover with your hand to release the tab holding the center of the cover in place.
  3. Lenovo Yoga 920-13IKB Fingerprint Sensor Replacement, Battery: step 3, image 1 of 3 Lenovo Yoga 920-13IKB Fingerprint Sensor Replacement, Battery: step 3, image 2 of 3 Lenovo Yoga 920-13IKB Fingerprint Sensor Replacement, Battery: step 3, image 3 of 3
    • Remove the four 5mm Phillips #00 screws that hold the battery in place.
  4. Lenovo Yoga 920-13IKB Fingerprint Sensor Replacement: step 4, image 1 of 2 Lenovo Yoga 920-13IKB Fingerprint Sensor Replacement: step 4, image 2 of 2
    • Grab the grouping of wires with your fingers close to the connector and gently pull to disconnect the battery from the motherboard.
    • The wire grouping is located underneath the thin flap near the center of the battery.
    • Do not lift the battery out before disconnection from the motherboard to prevent shortages or damage.
  5. Lenovo Yoga 920-13IKB Fingerprint Sensor Replacement: step 5, image 1 of 1
    • Use the iFixit Opening Tool to lift the battery up enough to grab it with your hands.
  6. Lenovo Yoga 920-13IKB Fingerprint Sensor Replacement: step 6, image 1 of 1
    • Remove the battery.
  7. Lenovo Yoga 920-13IKB Fingerprint Sensor Replacement, Fingerprint Sensor: step 7, image 1 of 1
    • Remove the 3mm Phillips #00 Screw to loosen the sensor.
  8. Lenovo Yoga 920-13IKB Fingerprint Sensor Replacement: step 8, image 1 of 1
    • Lift up the cover on the fingerprint sensor using the iFixit Opening Tool and remove the cover from the sensor.
  9. Lenovo Yoga 920-13IKB Fingerprint Sensor Replacement: step 9, image 1 of 1
    • Flip up the cable connector tab using the iFixit Opening Tool to release the ribbon wire.
  10. Lenovo Yoga 920-13IKB Fingerprint Sensor Replacement: step 10, image 1 of 1
    • Unplug the ribbon wire from the sensor to completely free the sensor.
  11. Lenovo Yoga 920-13IKB Fingerprint Sensor Replacement: step 11, image 1 of 1
    • Lift the fingerprint sensor with the iFixit Opening Tool and remove it from the device.
Alyssa McCulloch
1,990 Reputation
9 Guides authored
Cal Poly, Team S2-G3, White Winter 2019 Member of Cal Poly, Team S2-G3, White Winter 2019
CPSU-WHITE-W19S2G3
4 Members
29 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 2
All Time: 645
