Lenovo Yoga 920-13IKB Motherboard Replacement
  1. Lenovo Yoga 920-13IKB Motherboard Replacement, Back Cover: step 1, image 1 of 2 Lenovo Yoga 920-13IKB Motherboard Replacement, Back Cover: step 1, image 2 of 2
    • Flip the device over to access the screws on the back cover.
    • Remove the ten 5mm Torx T5 screws on the back cover to loosen the back cover.
  2. Lenovo Yoga 920-13IKB Motherboard Replacement: step 2, image 1 of 3 Lenovo Yoga 920-13IKB Motherboard Replacement: step 2, image 2 of 3 Lenovo Yoga 920-13IKB Motherboard Replacement: step 2, image 3 of 3
    • Slide the iFixit Opening Tool under the back cover to lift it up.
    • Pull up on the cover with your hand to release the tab holding the center of the cover in place.
  3. Lenovo Yoga 920-13IKB Motherboard Replacement, Motherboard: step 3, image 1 of 2 Lenovo Yoga 920-13IKB Motherboard Replacement, Motherboard: step 3, image 2 of 2
    • Remove the twelve 5mm Phillips #00 screws to loosen the motherboard.
  4. Lenovo Yoga 920-13IKB Motherboard Replacement: step 4, image 1 of 3 Lenovo Yoga 920-13IKB Motherboard Replacement: step 4, image 2 of 3 Lenovo Yoga 920-13IKB Motherboard Replacement: step 4, image 3 of 3
    • Flip up the ten flat connectors holding the motherboard using the iFixit Opening Tool to free the motherboard.
  5. Lenovo Yoga 920-13IKB Motherboard Replacement: step 5, image 1 of 2 Lenovo Yoga 920-13IKB Motherboard Replacement: step 5, image 2 of 2
    Tool used on this step:
    Buy
    • Pull out the ribbon cables from the opened connectors using the iFixit Tweezers to free up the motherboard.
  6. Lenovo Yoga 920-13IKB Motherboard Replacement: step 6, image 1 of 2 Lenovo Yoga 920-13IKB Motherboard Replacement: step 6, image 2 of 2
    • Disconnect the battery by pulling the ribbon wire grouping out of the top of the motherboard.
  7. Lenovo Yoga 920-13IKB Motherboard Replacement: step 7, image 1 of 2 Lenovo Yoga 920-13IKB Motherboard Replacement: step 7, image 2 of 2
    • Disconnect the red and black wire from the motherboard using the iFixit Tweezers.
  8. Lenovo Yoga 920-13IKB Motherboard Replacement: step 8, image 1 of 3 Lenovo Yoga 920-13IKB Motherboard Replacement: step 8, image 2 of 3 Lenovo Yoga 920-13IKB Motherboard Replacement: step 8, image 3 of 3
    • Lift the motherboard up parallel to the hinge of the device.
    • Gently pull away from the port cutouts of the USB-C and audio jack to remove the motherboard from the device casing.
    • Avoid pulling the motherboard all the way out until the green AC card is disconnected.
  9. Lenovo Yoga 920-13IKB Motherboard Replacement: step 9, image 1 of 3 Lenovo Yoga 920-13IKB Motherboard Replacement: step 9, image 2 of 3 Lenovo Yoga 920-13IKB Motherboard Replacement: step 9, image 3 of 3
    • Disconnect the green AC card plugged into the motherboard by pulling it out with your hands.
  10. Lenovo Yoga 920-13IKB Motherboard Replacement: step 10, image 1 of 1
    • Flip the motherboard over to access the back side.
  11. Lenovo Yoga 920-13IKB Motherboard Replacement: step 11, image 1 of 3 Lenovo Yoga 920-13IKB Motherboard Replacement: step 11, image 2 of 3 Lenovo Yoga 920-13IKB Motherboard Replacement: step 11, image 3 of 3
    • Remove four 3mm JIS #00 screws with the screwdriver.
    • Remove one 3mm Phillips #00 screw with the screwdriver.
    • The screws stay attached to the speaker when removed from the motherboard.
  12. Lenovo Yoga 920-13IKB Motherboard Replacement: step 12, image 1 of 1
    • Separate the fans from the motherboard to isolate it for replacement.
8 other people completed this guide.
Alyssa McCulloch
1,990 Reputation
9 Guides authored
Cal Poly, Team S2-G3, White Winter 2019 Member of Cal Poly, Team S2-G3, White Winter 2019
CPSU-WHITE-W19S2G3
4 Members
29 Guides authored
6 Comments
I need to fix my touchpad. It moves and clicks, but when i press down to click it does not work. It will only select thing by tapping, not clicking.
Roman Baca - Reply
Hi. I gave this guide a look, as I'm attempting to upgrade my SSD. I got things a bit out of order and pulled out one of the ribbon cables in step 5, before flipping up the tabs in step 4. I then gave up and put the ribbon cable back and replaced the screws. However, now the machine won't start. I can't see how removing and then replacing the ribbon cable might cause this. Does anyone have any ideas?
Dean Peart - Reply
False alarm! I must not have put a ribbon cable all the way back into its socket. After another check it all went back together and started without issue. Great guide. Thanks!
Dean Peart -
After removing the fan, do you need to do anything with the thermal paste? Remove it, replace it when you go to put the fan back together?
Alex Sammon - Reply
It depends on the quality of the thermal paste and how it has aged - If it’s still seemingly ‘wet’ (don’t touch it, just observe) then it’s likely fine to leave, but if it instead is ‘dry’ or visibly cracked then you should replace it. First, clean the CPU carefully with isopropyl alcohol and a lint-free towel. Then add an appropriate amount of thermal paste and reattach the heatsink assembly. Be sure to apply even force to each screw little-by-little when screwing it back in.
When in doubt, replace the thermal paste.
Chris -
Past 24 Hours: 1
Past 7 Days: 11
Past 30 Days: 96
All Time: 10,228
