Lenovo Yoga 920-13IKB Screen Replacement
  1. Lenovo Yoga 920-13IKB Screen Replacement, Screen: step 1, image 1 of 3 Lenovo Yoga 920-13IKB Screen Replacement, Screen: step 1, image 2 of 3 Lenovo Yoga 920-13IKB Screen Replacement, Screen: step 1, image 3 of 3
    • Rotate the device into tablet mode so the device’s screen is facing up.
  2. Lenovo Yoga 920-13IKB Screen Replacement: step 2, image 1 of 3 Lenovo Yoga 920-13IKB Screen Replacement: step 2, image 2 of 3 Lenovo Yoga 920-13IKB Screen Replacement: step 2, image 3 of 3
    • Pry the metal cover up from the bottom of the screen with the iFixit Opening Tool to reveal the corners of the white adhesive strip.
    • Pull the metal cover off the device until it's completely free.
    • Clean off the old adhesive and straighten the metal cover when reassembling.
    • Use a new adhesive when reassembling.
    • Avoid bending the metal cover to prevent damage to the device.
    • If you’re really struggling, you may pry from the opposite side, but be careful not to damage the screen or metal cover.
  3. Lenovo Yoga 920-13IKB Screen Replacement: step 3, image 1 of 2 Lenovo Yoga 920-13IKB Screen Replacement: step 3, image 2 of 2
    • Remove the eight 3mm Phillips #000 screws that were below the metal cover to loosen the screen.
  4. Lenovo Yoga 920-13IKB Screen Replacement: step 4, image 1 of 3 Lenovo Yoga 920-13IKB Screen Replacement: step 4, image 2 of 3 Lenovo Yoga 920-13IKB Screen Replacement: step 4, image 3 of 3
    Tool used on this step:
    Buy
    • Pull out the white adhesives using the iFixit Tweezers.
    • Roll the tape around the iFixit Tweezers to remove successfully.
  5. Lenovo Yoga 920-13IKB Screen Replacement: step 5, image 1 of 1
    • Pry up the screen with the iFixit Opening Tool.
  6. Lenovo Yoga 920-13IKB Screen Replacement: step 6, image 1 of 2 Lenovo Yoga 920-13IKB Screen Replacement: step 6, image 2 of 2
    • Lift the screen with your hands and place the the screen face down, keeping the device in the same location.
  7. Lenovo Yoga 920-13IKB Screen Replacement: step 7, image 1 of 1
    • Flip up the black tab on the connector at the top of the screen with the iFixit Opening Tool.
  8. Lenovo Yoga 920-13IKB Screen Replacement: step 8, image 1 of 1
    • Use the iFixit Tweezers to remove the ribbon cable from the connector.
  9. Lenovo Yoga 920-13IKB Screen Replacement: step 9, image 1 of 1
    • Flip up the black tab on the smallest connector at the bottom of the screen with the iFixit Opening Tool.
  10. Lenovo Yoga 920-13IKB Screen Replacement: step 10, image 1 of 1
  11. Lenovo Yoga 920-13IKB Screen Replacement: step 11, image 1 of 1
    • Flip up the thick black cable at the bottom of the screen with your thumb.
    • Use the iFixit Opening Tool to lift up the brass tab to free up the cable.
  12. Lenovo Yoga 920-13IKB Screen Replacement: step 12, image 1 of 1
    • Remove the ribbon cable from the connector to detach the screen from the device.
Alyssa McCulloch
1,990 Reputation
9 Guides authored
Cal Poly, Team S2-G3, White Winter 2019 Member of Cal Poly, Team S2-G3, White Winter 2019
CPSU-WHITE-W19S2G3
4 Members
29 Guides authored
5 Comments
Does this also appy to the Yoga 910-13IBK?
Tony Salazar - Reply
Alyssa, I am about to tackle this job to replace a cracked screen - I greatly appreciate your guide. In step 2 you recommend using new adhesive. What adhesive is recommended exactly?
Bradley Buege - Reply
See this youtube video from Lenovo on LCD tape, how to find what kind, how to remove it, and how to reapply it.
https://www.youtube.com/watch?v=EeUM312_...
Robert -
You missed the camera transfer step. I completed the screen replacement only to find no camera for Zoom. Then realized the this procedure didn’t cover the camera transfer.
ddurbin1 - Reply
Ok, 15 minutes to complete this is ridiculous. A seasoned person couldn't do this in 15 minutes, especially when removing and replacing adhesive, etc. That must be a typo.
Syber Geek - Reply
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 24
All Time: 6,011
