Lenovo Yoga 920-13IKB USB 3.0 Port Replacement
  1. Lenovo Yoga 920-13IKB USB 3.0 Port Replacement, Back Cover: step 1, image 1 of 2 Lenovo Yoga 920-13IKB USB 3.0 Port Replacement, Back Cover: step 1, image 2 of 2
    • Flip the device over to access the screws on the back cover.
    • Remove the ten 5mm Torx T5 screws on the back cover to loosen the back cover.
  2. Lenovo Yoga 920-13IKB USB 3.0 Port Replacement: step 2, image 1 of 3 Lenovo Yoga 920-13IKB USB 3.0 Port Replacement: step 2, image 2 of 3 Lenovo Yoga 920-13IKB USB 3.0 Port Replacement: step 2, image 3 of 3
    • Slide the iFixit Opening Tool under the back cover to lift it up.
    • Pull up on the cover with your hand to release the tab holding the center of the cover in place.
  3. Lenovo Yoga 920-13IKB USB 3.0 Port Replacement, USB 3.0 Port: step 3, image 1 of 2 Lenovo Yoga 920-13IKB USB 3.0 Port Replacement, USB 3.0 Port: step 3, image 2 of 2
    Tool used on this step:
    Buy
    • Disconnect the red and black wire connected to the speaker using the iFixit Tweezers.
  4. Lenovo Yoga 920-13IKB USB 3.0 Port Replacement: step 4, image 1 of 1
    • Lift up the black tab on the flat cable connector with the iFixit Opening Tool.
  5. Lenovo Yoga 920-13IKB USB 3.0 Port Replacement: step 5, image 1 of 3 Lenovo Yoga 920-13IKB USB 3.0 Port Replacement: step 5, image 2 of 3 Lenovo Yoga 920-13IKB USB 3.0 Port Replacement: step 5, image 3 of 3
    • Flip up the tab using the iFixit Tweezers to release the flat cable.
  6. Lenovo Yoga 920-13IKB USB 3.0 Port Replacement: step 6, image 1 of 2 Lenovo Yoga 920-13IKB USB 3.0 Port Replacement: step 6, image 2 of 2
    • Undo the two 3mm Phillips #00 screws to loosen the USB 3.0 board.
  7. Lenovo Yoga 920-13IKB USB 3.0 Port Replacement: step 7, image 1 of 3 Lenovo Yoga 920-13IKB USB 3.0 Port Replacement: step 7, image 2 of 3 Lenovo Yoga 920-13IKB USB 3.0 Port Replacement: step 7, image 3 of 3
    • Remove the USB 3.0 Board from the device using the iFixit Opening Tool.
3 other people completed this guide.
Alyssa McCulloch
1,990 Reputation
9 Guides authored
Cal Poly, Team S2-G3, White Winter 2019 Member of Cal Poly, Team S2-G3, White Winter 2019
CPSU-WHITE-W19S2G3
4 Members
29 Guides authored
One Comment
Just wanted to say thank you to Alyssa and the others who contributed to this.
I just used your guide to fix a problem with my Yoga constantly entering and waking (repeatedly, seconds apart) from connected sleep mode. Infuriating. It was accompanied by the USB connect/disconnect sound as well.
Using the Event Viewer I managed to find out it was entering sleep mode in response to the power button (which I wasn’t pressing). So, I used your guide to disconnect and reconnect the USB board and it has resolved my issue.
iFixIt gained some tools income, you gained some more reputation points, and I gained a laptop that’s behaving itself now!
Now, what else can I break? ;o)
Sean Puffett - Reply
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 12
All Time: 2,183
