Lenovo Yoga C930-13IKB Back Cover Replacement
  1. Lenovo Yoga C930-13IKB Back Cover Replacement, Back Cover: step 1, image 1 of 1
    • Flip the device over so that the underside is facing up.
    • Remove the six 3.5 mm T5 Torx screws.
  2. Lenovo Yoga C930-13IKB Back Cover Replacement: step 2, image 1 of 2 Lenovo Yoga C930-13IKB Back Cover Replacement: step 2, image 2 of 2
    • Pry off the back cover using the plastic opening tool.
    • Loosen the back cover in multiple spots using the opening tool, then remove the whole back.
    • You may have to run the plastic tool along the edges until you find a small gap to separate the back cover from the laptop.
    • Do not use a metal tool when working with your device.
  3. Lenovo Yoga C930-13IKB Back Cover Replacement: step 3, image 1 of 2 Lenovo Yoga C930-13IKB Back Cover Replacement: step 3, image 2 of 2
    • Carefully lift the cover off with your hands.
2 other people completed this guide.
Hanna Lazkani
788 Reputation
3 Guides authored
Cal Poly, Team S19-G5, White Winter 2020 Member of Cal Poly, Team S19-G5, White Winter 2020
CPSU-WHITE-W20S19G5
4 Members
16 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 17
Past 30 Days: 65
All Time: 2,884
