Lenovo Yoga Tab 3 10 Camera Replacement
  1. Lenovo Yoga Tab 3 10 Camera Replacement, Back Cover: step 1, image 1 of 1
    • Open the built-in kickstand.
  2. Lenovo Yoga Tab 3 10 Camera Replacement: step 2, image 1 of 3 Lenovo Yoga Tab 3 10 Camera Replacement: step 2, image 2 of 3 Lenovo Yoga Tab 3 10 Camera Replacement: step 2, image 3 of 3
    • Remove the sticker located directly under the the built-in kickstand to reveal two 0.75 mm screws.
    • Remove the microSD card slot cover. Remove any microSD card (if inserted).
    • Using a Phillips head screwdriver, remove the three 0.75 mm screws.
    On 3 plus model the third screw is not under microSD card but rather under a small sticker on the right side. Plus has longer battery.
    George - Reply
    on the Tab 3 plus , the third screw is not under the sd card but a little further over under another sticker and is painted white
    dan o brien - Reply
  3. Lenovo Yoga Tab 3 10 Camera Replacement: step 3, image 1 of 3 Lenovo Yoga Tab 3 10 Camera Replacement: step 3, image 2 of 3 Lenovo Yoga Tab 3 10 Camera Replacement: step 3, image 3 of 3
    • Orient the device so the screen is facing you.
    • Carefully insert the spudger along the seam between the screen and back cover and gently separate the back cover from the device frame.
    • Continue to detach the backplate from the frame by moving the spudger around the perimeter.
    • Some force will be required to detach the small plastic braces securing the backplate to the device.
    On some models there is glue pad under the sim/sdcard tray.
    Ervins Stepanovs - Reply
    Ein Hinweis auf den Federrahmen an der Kamera wäre nützlich. Er ist sehr empfindlich. Ich habe ihn beim Öffnen zerstört und jetzt stellt die Kamera nicht mehr scharf.
    Thomas Spieker - Reply
    Hallo Thomas, tut mir leid, dass deine Kamera nicht mehr schart stellt. Aber die Anleitungen funktionieren wie Wikipedia: Wenn du mehr Infos hast, stelle sie gern allen anderen zur VerfĂĽgung!
    Fabian Neidhardt -
    (at least on the Plus model) the most difficult plastic clips are near the micro-SD/SIM. So it is easier to release the other side, where the camera not is. or pull the casing "down" towards the battery/stand.
    Hans Wurst - Reply
  4. Lenovo Yoga Tab 3 10 Camera Replacement, Camera: step 4, image 1 of 3 Lenovo Yoga Tab 3 10 Camera Replacement, Camera: step 4, image 2 of 3 Lenovo Yoga Tab 3 10 Camera Replacement, Camera: step 4, image 3 of 3
    • Remove the 3 screws from the auxiliary port cover.
    • Use the spudger to gently push the auxiliary module out of the way.
    • Remove the detachable plastic latch located in front of the hinge.
  5. Lenovo Yoga Tab 3 10 Camera Replacement: step 5, image 1 of 1
    • Use a spudger to gently remove the hinge.
  6. Lenovo Yoga Tab 3 10 Camera Replacement: step 6, image 1 of 1
    • Carefully lift the kickstand away from the frame.
    • The battery is located inside of the kickstand. Ensure proper handling and care.
  7. Lenovo Yoga Tab 3 10 Camera Replacement: step 7, image 1 of 2 Lenovo Yoga Tab 3 10 Camera Replacement: step 7, image 2 of 2
    • Use the pointed end of a spudger to push in the camera's locking mechanism.
    • Upon releasing the camera lock lift the camera out and locate the three screws.
  8. Lenovo Yoga Tab 3 10 Camera Replacement: step 8, image 1 of 3 Lenovo Yoga Tab 3 10 Camera Replacement: step 8, image 2 of 3 Lenovo Yoga Tab 3 10 Camera Replacement: step 8, image 3 of 3
    • Use a J000 Philips screwdriver to remove the three screws.
    • Remove the camera cover that seals the camera case.
    • Remove the camera from the shell.
  9. Lenovo Yoga Tab 3 10 Camera Replacement: step 9, image 1 of 1
    • Separate the camera from its casing.
2 other people completed this guide.
Phanudej
1,190 Reputation
5 Guides authored
USF Tampa, Team S3-G2, Sullivan Spring 2017 Member of USF Tampa, Team S3-G2, Sullivan Spring 2017
USFT-SULLIVAN-S17S3G2
4 Members
18 Guides authored
One Comment
Thanks for describing in details with bit and peaces very neatly and clearly. I fix the problem of my Lenovo Yoga 3 with help of this. Great job you have done.. keep it up… Sisira
Sisira Kumara - Reply
Past 24 Hours: 4
Past 7 Days: 5
Past 30 Days: 37
All Time: 4,266
