Lenovo Yoga Tablet 2 830-F Camera Replacement
  1. Lenovo Yoga Tablet 2 830-F Camera Replacement, Camera: step 1, image 1 of 2 Lenovo Yoga Tablet 2 830-F Camera Replacement, Camera: step 1, image 2 of 2
    • Remove the three screws on the back of the device with the Phillips Screwdriver #00 bit.
    • Using the blue opening tools or spudger, gently remove the back cover to expose the interior of the tablet.
  2. Lenovo Yoga Tablet 2 830-F Camera Replacement: step 2, image 1 of 3 Lenovo Yoga Tablet 2 830-F Camera Replacement: step 2, image 2 of 3 Lenovo Yoga Tablet 2 830-F Camera Replacement: step 2, image 3 of 3
    • Using the Phillips Screwdriver #00 bit remove the 6 screws.
    • Using the Phillips Screwdriver #00 bit remove the 3 screws.
    • After removing all the screws, disconnect the ribbon cables.
    • Disconnect the ZIF connectors.
    • Some of the ribbon cables are secured with clips, simply pry up the clips before sliding them out of the pin connectors.
  3. Lenovo Yoga Tablet 2 830-F Camera Replacement: step 3, image 1 of 3 Lenovo Yoga Tablet 2 830-F Camera Replacement: step 3, image 2 of 3 Lenovo Yoga Tablet 2 830-F Camera Replacement: step 3, image 3 of 3
    • After removing the motherboard and antennas the camera module is located on the right as marked in red.
    • Remove the three 2mm screws holding the module in place with the Phillips Screwdriver #00 bit.
    • The camera module is also held in place with adhesive so gently remove.
Mario Gjyli
449 Reputation
3 Guides authored
USF Tampa, Team S2-G4, Nance Fall 2017 Member of USF Tampa, Team S2-G4, Nance Fall 2017
USFT-NANCE-F17S2G4
3 Members
12 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 12
All Time: 683
