Lenovo Z70-80 Keyboard Replacement
  1. Lenovo Z70-80 Keyboard Replacement, Battery: step 1, image 1 of 2 Lenovo Z70-80 Keyboard Replacement, Battery: step 1, image 2 of 2
    • Use your fingers two push both latches away from each other to release the battery.
    • Pull the battery out.
  2. Lenovo Z70-80 Keyboard Replacement, Keyboard: step 2, image 1 of 3 Lenovo Z70-80 Keyboard Replacement, Keyboard: step 2, image 2 of 3 Lenovo Z70-80 Keyboard Replacement, Keyboard: step 2, image 3 of 3
    • Carefully pry up the keyboard with the flat end of a spudger and remove all of the 3mm Phillips #0 screws.
    • Use a spudger to flip up the retaining flap on the keyboard ribbon cable ZIF socket.
    • Pull the keyboard cable out of the socket.
    • Remove the keyboard.
Eduardo Delgado
412 Reputation
4 Guides authored
Gateway, Team S1-G4, Johnson Spring 2018 Member of Gateway, Team S1-G4, Johnson Spring 2018
GCC-JOHNSON-S18S1G4
2 Members
12 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 10
All Time: 1,607
